Logitech just announced the Wireless Mouse M320, designed with a curved shape to guide your hand to a natural position. With the asymmetrical form, a wide wheel that improves the scrolling experience and the Logitech Advanced Optical Sensor to provide enhanced precision and responsiveness, this mouse fits any of your needs, whether you’re hard at work or just browsing the Internet.
The Logitech Wireless Mouse M320 is compatible with all major operating systems, and it has an integrated sensor for precise tracking and smooth cursor control. Thanks to advanced energy-efficient engineering, the mouse automatically puts itself to sleep when you are not using it so you can go longer between battery changes. Plus, the Nano receiver gives you the reliability of a cord and the convenience of wireless freedom. With the modern design and several color options, this mouse easily fits neatly into any workspace.
“With the considerable amount of time each day that we all spend using desktops, laptops and tablets, it is really important that our input devices are comfortable to use,” said Charlotte Johs, global vice president of computer peripherals at Logitech. “We used a handcrafted process to create the Logitech Wireless Mouse M320, and this design technique allowed us to achieve a dynamic, curved shape with a soft rubber grip that is naturally comfortable for the hand.”
Pricing and Availability
The Logitech Wireless Mouse M320 is expected to be available in the U.S. and Canada beginning this month for $29.99. Four color options include black, red, blue or gray/yellow.
