Accessories
Logitech Keys-To-Go Keyboard for iPad
Logitech Keys-To-Go
Logitech announced three new mobile keyboards for iPad Air 2, priced under $100. The first is a slender, $70 stand-alone Bluetooth keyboard for any iPad that can fit anywhere and go everywhere. The new Logitech Keys-To-Go ultra-portable keyboard is thin, light and durable at just 6.1 mm and 180 grams. To ensure a comfortable typing experience, its keys give you the tactile feedback you’re used to on your laptop, but are fused into a water-repellant FabricSkin covering that helps protect the keyboard from spills and dirt – so no crumbs get stuck in your keys and liquids wipe right off. The rechargeable battery can last up to three months on a complete charge. The keyboard is compatible with all generations of the iPad and iPad mini and is available in three colors – black, red and teal
The Logitech Ultrathin is a thin and light magnetic clip-on keyboard cover for your iPad Air 2. The cover protects the screen of your tablet when you’re on the go and is constructed from high-grade aluminum material that perfectly matches the iPad Air 2; it is the other half of your iPad Air 2. Plus, the keyboard has a battery life that can go up to two years, and the batteries can easily be replaced when needed. The adjustable magnetic slot lets you tilt your iPad similar to a laptop screen for the perfect typing angle. The Logitech Ultrathin for iPad Air 2 is available in Space Grey and Silver.
The Logitech Type+ is an all-in-one keyboard case for the iPad Air 2. It leverages the popular thin and light, two-sided protective case from its predecessor, and has a recently-optimized Bluetooth keyboard that is designed to replicate the typing experience of your laptop, so you can smoothly transition from one device to another without losing speed or accuracy. When in the typing position, the iPad screen magnetically attaches directly above the keyboard, keeping the screen right at your fingertips for easy navigation. The Logitech Type+ keyboard also has an automatic On/Off feature; when the iPad is positioned upright in the typing position, the Logitech Type+ keyboard automatically turns on, and when you lay it flat for browsing, it automatically turns the keyboard off. In addition, the auto-wake and auto-sleep feature turns your iPad off when you close the case and wakes it when you open the case, so your iPad is ready anytime you need it. The Logitech Type+ is available in Black, Dark Blue, Bright Red, Bright Green, Electric Blue or Violet
Pricing and Availability (November 2014)
  • Logitech Keys-To-Go $69.99
  • Logitech Ultrathin for iPad Air 2 $89.99
  • Logitech Type+ for iPad Air 2 $99.99
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
UE introduces four new 4th generation portable Bluetooth speakers: WonderBoom 4, Boom 4, MegaBoom 4 and EverBoom.
Shop this season's best DTS powered products for everyone on your list - from gamers, music lovers, content creators, and cinephiles.
Waterproof, floatable, and designed to take a beating outside by the pool, the Ultimate Ears EPICBOOM Bluetooth speakers have arrived.
Mouse
Logitech announced the Wireless Trackball M570, uniquely designed for all-day comfort and features the leave-in Logitech® Unifying receiver. For those who haven’t tried a...
The $399 UE HYPERBOOM is a Bluetooth wireless speaker that is the biggest, loudest and bassiest from the Ultimate Ears BOOM lineup.
Ultimate Ears released the cylinder-shaped UE Boom portable speaker last year for $200 in a range of colors and designs. For 2015, the company...
Moldable wireless earbuds fit into any ear so they stay in place for comfort, convenience and sound quality.
Ultimate Ears today announced a limited-edition, artist inspired version of the UE BOOM 2 portable Bluetooth speaker designed by Austrian graffiti illustrator Nychos. The...
