Laptops
The Limited Edition Diamond Notebooks from Ego Lifestyle really are a girls best friend!
A diamond encrusted laptop?
Whilst desktop PC’s seem to be undergoing somewhat of an image overhaul, it would be true to say that the design of laptop computers can be fairly dull, however this is certainly not the case as far as the Ego Diamond is concerned.
The Ego Diamond by Ego Lifestyle certainly doesn’t pull any punches as far as announcing itself is concerned. Featuring no less than 470 separate, highly sought after Wesselton V.S. Diamonds set in 18 carat white gold and a handmade back leather finished casing (with a chrome handle just for good measure) this is surely the ultimate bling as far as laptops are concerned.
In a class of its own, the limited edition Ego Diamond was designed and created by Master Goldsmith Laurent de Beer. These special models have elements featuring precious diamonds set with surgical presicion in white gold.
These models are available as numbered limited editions in a numbered run of only 100.
In addition to these limited edition models, Ego Lifestyle can design tailormade Diamond Ego’s entirely to the buyer’s desires and specifications, so if you have a spare £50,000 then you can command the style of your choice!
Whilst these editions probably won’t sell as fast as hot cakes, there are only 100 of them in this spectacular limited edition. Diamonds really are a girls best friend!
See Ego diamond pictures and specification by visiting; www.atecassociates.com
or contact ATEC Associates – info@atecassociates.com or visit www.wi5.com
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
