Liberty Wire & Cable Introduces Revolutionary HDMI Over COAX Transmitter/Receiver System
Easy to Install and Use, Compact New DigitaLinx Device Extends HDMI’s Reach Using Analog Cabling; Ideal for A/V Retrofits and Upgrades
Liberty Wire & Cable, worldwide supplier of a broad range of wire and cable products for the audio/video trade, including custom installers and systems integrators, introduces a revolutionary new HDMI over COAX Transmitter/Receiver System at INFOCOMM International 2008, the annual convention of the International Communications Industries Association, beginning here later this month.
The HDMI over COAX Transmitter/Receiver is the newest addition to Liberty’s extensive DigitaLinx family of products, further enhancing Liberty’s position as the industry leader in long-distance HDMI technology. Devices like Liberty’s compact new Transmitter/Receiver system transmit true HDMI signals, not an analog version of a digital signal, over already installed coaxial cable, eliminating the need to run all-new wires throughout a home or office. Liberty’s device is easy to install and use, works perfectly with the RGBHV coax cables typically used for VGA or component signals, and provides A/V professionals with unparalleled flexibility.
Also significant: Liberty’s system is the only HDMI extender designed to function using the HDMI 1.3 standard at a high enough speed (10.2 Gbps) to future-proof new installations. Tests indicate 1080p performance at distances over 300 feet with common cables.
“Liberty’s new HDMI over COAX device is ideal for retrofitting existing analog A/V systems,” says Kirk Horlbeck, Senior Vice President of Marketing. “With the switch from analog to digital picking up speed, and Blu-Ray and 1080p being adopted as industry standards, it’s quickly becoming essential to provide custom professionals with an HDMI 1.3 Category 2 solution utilizing existing cables.”
Consisting of a transmitter module and a receiver module, the HDMI Over COAX system uses conventional HDMI cable to connect to sources and displays. Four or five conductor coax cables are used to connect the transmitter to the receiver, and the power plug can work at either end. There are LED status indicators for Display, Source and Power. With its small form-factor and ease of use, it significantly extends the reach of HDMI over existing coax cabling.
“Liberty’s HDMI Over COAX will help build our customers businesses and their bottom lines,” says John Dace, Vice President of Sales. “HDMI over COAX allows A/V professionals to move their current analog customer base to HDMI signal distribution by executing a Liberty HDMI upgrade. With a simple on-site visit, they will be able to extend the life-spans of their customers’ current analog installations while providing AV professionals with opportunities to upgrade displays, entertainment sources, cables, and switchers.”
The HDMI over COAX Transmitter/Receiver system can be seen with Liberty’s other outstanding products at Liberty’s Exhibit Booth C3160, Las Vegas Convention Center, during the show.
About Liberty Wire & Cable
Liberty, a division of Communications Supply Corp. (CSC), is headquartered in Colorado Springs, Colo., and is in its 17th year of operation. Its core goods, sold primarily for audio/video and security applications, consist of a complete line of wire and cable products along with connectors and connector systems, cable assemblies, interconnects, and a broad range of related accessories. Liberty principally serves the residential, commercial, broadcast, and rental and staging segments of the pro/AV industry. It also enjoys long-term relationships with a number of prominent OEMs. Liberty manufactures and markets the PanelCrafters line of custom and stock plates and panels. The company, which sells in 49 countries, has other facilities in Charlotte, N.C., and Phoenix, Ariz., and holds memberships in CEDIA, InfoComm International, and NSCA.
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
