Liberty Wire & Cable Introduces DigitaLinx HDMI Multiplexer
New System Integration Device Combines Best Features of a Distribution Amplifier and Switcher; Ideal for Home Theaters
Liberty Wire & Cable, worldwide supplier of a broad range of wire and cable products for the audio/video trade, including custom installers and systems integrators, has introduced a new HDMI Multiplexer as part of its family of DigitaLinxTM digital solutions for custom installation and A/V professionals.
Liberty’s new HDMI Multiplexer, Model DL-HDM66, combines the best features of a distribution amplifier and a switcher. It features six inputs and six outputs, and allows six different digital A/V sources (such as a DVD player, a set-top box and a computer) to be split into multiple digital displays.
The versatile multiplexer is ideal for Home Theater system integration, and easy switching between different sources, since it eliminates the hassle of manually plugging in different HDMI connectors to view different sources. It’s also well suited for use in monitoring systems and Home Theaters with multiple displays, and for testing equipment. It supports high-quality HDTV resolution up to 1080p, and complies with the High-Definition Content Protection (HDCP) standard.
The DigitaLinx family incorporates a variety of additional devices — including digital repeaters, distribution amplifiers, and fiber optic solutions — that extend and route DVI and HDMI signals in residential and commercial installations. They provide an enormous number and variety of solutions for installation and AV professionals working in a world of merging technologies dependent on digital information. The well-designed and integrated DigitaLinx solutions keep businesses competitive and profitable, while further expanding the Liberty Advantage.
Liberty’s new HDMI Multiplexer is available now from authorized Liberty dealers. Digital Solutions for the Residential Contractor, a detailed, four-color brochure that fully describes the entire DigitaLinx line, can be obtained, free of charge, by calling Liberty Wire & Cable at 1- 800-530-8998.
About Liberty Wire & Cable
Liberty, a division of Communications Supply Corp. (CSC), is headquartered in Colorado Springs, Colo., and is in its 16th year of operation. Its core goods, sold primarily for audio/video and security applications, consist of a complete line of wire and cable products along with connectors and connector systems, cable assemblies, interconnects, and a broad range of related accessories. Liberty principally serves the residential, commercial, broadcast, and rental and staging segments of the pro/AV industry. It also enjoys long-term relationships with a number of prominent OEMs. Liberty manufactures and markets the PanelCrafters line of custom and stock plates and panels. The company, which sells in 49 countries, has other facilities in Charlotte, N.C., and Phoenix, Ariz., and holds memberships in CEDIA, InfoComm International, and NSCA.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
