Liberty Wire & Cable Introduces ConnecTec — Unique All-in-One Coax Termination Solution
FOR IMMEDIATE RELEASE
CONTACT:
J. B. Stanton Communications:NYC/CT/LA/HK
860/542-1234 Voice • 860/542-0005 Fax
Stan Pinkwas / [718] 788-7777 Voice
stanp@jbstanton.com
Bryan Stanton / jbs@jbstanton.com
Liberty Wire & Cable Introduces ConnecTec ™ — Unique All-in-One Coax Termination Solution
Problem-Solving ConnecTecTM Termination System Features Unique Ergonomic Tools, Durable Metal Connectors and Compact Installation Case
CEDIA EXPO, Indianapolis, Sept. 9, 2005 — Liberty Wire & Cable, worldwide supplier of a broad range of wire and cable products for the audio/video trade, including custom installers and systems integrators, introduces the ConnecTec™ Termination System, the industry’s most complete coaxial termination solution, to the custom installation community at the Custom Electronic Design and Installation Association (CEDIA) Expo 2005, beginning here today.
The ConnecTec™ System includes an extensive line of advanced, engineered BNC, F and RCA coaxial connectors in more than 60 styles, a new ergonomically designed crimp tool, and a pair of coaxial strippers — all housed in a specially designed installation case that’s both durable and compact.
Coaxial connectors play a critical role in signal transmission and Liberty offers AV professionals the broadest connector selection in the industry. The new 360-degree ConnecTec BNC, F and RCA radial-crimp connectors fit RG59, RG6 and RG6 Quad cables, as well as BNC and RCA cables for 25- and 26-gauge RGB mini coaxials.
ConnecTec connectors feature all-metal construction for maximum durability, an innovative inspection “window” to assure perfect termination, color banding for instant application identification, and color O-rings to simplify matching.
The easy-to-use crimp tool, engineered specifically for Liberty’s new ConnecTec coaxial connectors, is milled from a solid piece of NASA-grade aluminum and anodized in a bright red finish. A must-have for every installer, this exclusive time-saving tool is unique in that it terminates BNC, F and RCA connectors without using any adaptors or dies.
Sleek in design and easy to handle, Liberty’s new ConnecTec strip tools include one that accurately strips RG59, RG6 and RG6 Quad cables, and another that strips 25- and 26-gauge RGB mini coaxial cables. Both tools provide a perfect industry standard quarter-inch strip, and all the connectors work with Liberty’s CoaxMaster system, so there’s no need to retool.
The ConnecTec Termination System is available now from authorized Liberty dealers. It can be seen with Liberty’s other fine products at Booth 822, Indiana Convention Center, during CEDIA EXPO.
About Liberty Wire & Cable
Liberty is headquartered in Colorado Springs, Colo., and is in its 14th year of operation. Its core goods, sold primarily for audio/video and security applications, consist of a complete line of wire and cable products along with connectors and connector systems, cable assemblies, interconnects. and a broad range of related accessories. Liberty principally serves the residential, commercial, broadcast, and rental and staging segments of the pro/AV industry. It also enjoys long-term relationships with a number of prominent OEMs. Liberty manufactures and markets the PanelCrafters line of custom and stock plates and panels. The company, which sells in 49 countries, has other facilities in Charlotte, N.C., and Phoenix, Ariz., and holds memberships in CEDIA, ICIA, and NSCA.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
