LG Announces XL5 and XL7 XBOOM Bluetooth Party Speakers
The LG XBOOM XL5 and XL7 are portable suitcase sized wireless speakers that bring music and a lightshow to any size party, indoor or out.
LG XL7 XBOOM Party Speaker Portable Lifestyle
Spring is almost upon us and that means only one thing — outdoor party time by the pool or picnics in the park with the kids. Consumers have a lot of options in 2023 when it comes to portable outdoor loudspeakers and LG is making a strong play for that business.
In addition to its OLED TVs and Soundbars, LG makes a lot of other entertainment products, including its XBOOM speaker line. XBOOM speakers are designed for party and on-the-go entertainment. For 2023, LG is adding to its XBOOM Speaker product line with the new XL7 and XL5 models. Let’s check out what they have to offer.
LG XL5 and XL7 XBOOM Party Speakers Angle
LG XL5 (left) is about 6-inches shorter than XL7 (right)
Shared Features
Bluetooth and USB: Both speakers incorporate Bluetooth ver 5.1 with SBC and AAC codec support. The XL7 and XL5 speakers also provide a USB input for music playback from USB flash drives.
Karaoke: The XL7 and XL5 both include Karaoke capability with a mic and guitar input with Echo Control and Karaoke Star features.
Wireless Party Link: LG’s Wireless Party Link feature allows you to wirelessly connect up to 10 LG XL7 or XL5 speakers for a room or home-filling music listening experience.
XBOOM App:  LG also includes access to the XBOOM app (iOS/Android). This allows users to easily use the feature and setting controls for XBOOM speakers. The app also provides a DJ function that can make you the true life of the party.
Multi-Color Ring Lighting: This produces light shows with various rotating, flashing effects that perfectly sync to the music to add an extra dimension to the listening experience.
Customizable Lighting: This feature allows users to choose their own colors, patterns, animations, and personalized messages via the XBOOM app to create custom lighting effects that perfectly match their mood or playlist.
Weatherproof Rating: The XBOOM party speakers also boast an IPX4 rating. This means that users can enjoy music outdoors without worry, even around a swimming pool or in the bathroom.
XL7 Specific Features
LG XL7 XBOOM
Speakers: XL7 includes two 2.5-inch dome tweeters to provide needed high-frequency clarity as well as an 8-woofer for a deeper bass response.
Power Output: The XL7 can fill any room with up to 250 watts of audio output.
Dynamic Bass Optimizer: This feature enhances sound further by punching up the bass without bass distortion. This especially helps when playing content at low volume as it automatically increases the bass levels.
Portability: The XL7 is equipped with a telescopic handle and wheels for easy portability.
Playtime: The XL has a 20-hour playtime after a 3.5-hour charge.
Pixel LED lighting: This feature comes with Animation Mode which expresses colorful patterns, a Visual EQ effect, characters, or customized text on the speaker’s LED panel to enrich the atmosphere of any space.
XL5 Specific Features
LG XL5 XBOOM Party Speaker
LG XL5 XBOOM
Speakers: The XL5 incorporates the same 2.5-inch tweeters as the XL7 but a smaller 6.5-inch Woofer:
Power Output: The XL5 provides up to  200 watts of audio output.
Portability: The XL5 is smaller than the XL7 and has a carry handle, but it’s not a telescoping handle as is provided with the XL7. As a result, it is a little more inconvenient to move.
Light Effects: Similar to the XL7 it also has party lights but doesn’t have the added Pixel LED festure.
Playtime: The XL5 has less battery playtime than the XL7 with 12 hours after a 3.5-hour charge time.
Comparison
XL5XL7
Size
(W x H x D)
11.1 x 22.4 x 11 inches
282 x 570 x 280 mm
12.2 x 28 x 12.4 inches
310 x 700 x 316 mm
Weight26.5 lbs
12kg
32.5 lbs.
14.7kg
Total Wattage200W250W
Channels1.1ch / 2 Way1.1ch / 2 Way
Woofer6.5” Woofer8” Woofer
Tweeter2.5” Tweeter x 22.5” Tweeter x 2
Pixel LED lightingY
Multi Color Ring LightingYY
Karaoke1 Mic + 1 Guitar in Echo Control / Karaoke Star1 Mic + 1 Guitar in Echo Control / Karaoke Star
DJ FunctionY (App)Y (App)
Wireless Party LinkDual (L/R Stereo) /
Multi (Up to 10EA)
Dual (L/R Stereo) /
Multi (Up to 10EA)
Water ResistanceIPX4IPX4
Battery Charging Time / Battery Life3.5 hrs / 12 hrs3.5 hrs / 20 hrs
Grab & MoveHandleTelescoping Handle /casters
Bluetooth Ver5.15.1
Bluetooth Audio formatSBC, AACSBC, AAC
USB file playbackYY
Pricing and Availability
Update: On April 7, 2023 LG announced pricing as follows:
Hisense S5 DecoTV Front Lifestyle
Hisense’s S5 DécoTV proves not every TV needs to be enormous, blindingly bright, or pretending to be a gaming rig—just a smart, good-looking 32-inch...
LG Micro RGB Evo TV 2026 LG Micro RGB Evo TV 2026
LG previews its Micro RGB evo MRGB95B 4K TV ahead of CES 2026, marking a rare LCD shift with bold color claims, AI processing,...
2026 Samsung R95H 4K TV Angle 2026 Samsung R95H 4K TV Angle
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Our picks for best televisions of 2025 offer the best picture quality and value at their price and size.
Shopping for a new TV? Our picks for best televisions of 2024 provide the best picture quality and value at their price and size.
The Edifier MR5 delivers impressive near neutral accuracy, deeper bass, LDAC support and true three-way power for $350, making it a top budget studio...
Sony's flagship soundbar system will add punch to your movie and TV viewing and music listening, but at a price.
Compare every 2025 ultra-short throw (UST) 4K projector to decide which one is right for you.
Four flagship OLED TVs enter a dark room. But only one can emerge the winner.
After two years, LG dumps MLA. Find out what it is being replaced with and what it means for TV buyers
