LG Stylus 2 Smartphone is for Notetakers
LG announced the mid-range Stylus 2 Android smartphone, which boasts a real pen-like feel and more accuracy when notetaking and drawing compared to a rubber-tipped pen. The LG Stylus 2 is noticeably thinner and lighter than its predecessor, the LG G4 Stylus. At only 7.4mm thin and weighing just 145g, the slim 5.7-inch phone is complemented by a protruded flat display, Spin Hairline pattern on the back and metallic frames on all its edges. The LG Stylus 2 sports a high-capacity 3,000mAh removable battery and a SD card slot.
The LG Stylus 2 works just like using a real pen and memo pad with features like the new Calligraphy Pen font that allows one to write as beautifully and decoratively as if using a fountain pen. Also new is Pen Keeper, which prevents the stylus from being misplaced by displaying a popup message when the phone is detected as being in motion when the stylus bay is empty. The LG Stylus 2 also features Pen Pop which toggles a popup menu when the stylus is removed for shortcuts to Pop Memo and Pop Scanner.
Price and Availability
Due out sometime this year. Price TBD.
Specifications:
  • Display: 5.7-inch HD In-Cell Touch (1280 x 720)
  • Chipset: 1.2GHz Quad-Core
  • Camera: Rear 13MP / Front 8MP
  • Memory: 1.5GB LPDDR3 RAM / MicroSD
  • Battery: 3,000mAh (removable)
  • Operating System: Android 6.0 Marshmallow
  • Size: 155 x 79.6 x 7.4mm
  • Weight: 145g
  • Network: LTE / HSPA+ / GSM
  • Connectivity: Wi-Fi 802.11 b, g, n / Bluetooth 4.1 / USB 2.0
  • Colors: Titan / White / Brown
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
HDTV 4K & 8K TV
DTS support has disappeared from 2025 LG TVs. Is there something else afoot to replace it that might be better?
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HDTV 4K & 8K TV
At $59,999, the LG SIGNATURE OLED T is the most expensive 77-inch TV in the world. It looks like a pane of glass you...
Daily Deals
Now is the time for great deals on great-looking TVs. Here are our picks for the best Black Friday TV deals from 48 to...
Daily Deals
Our favorite soundbars on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
The Chinese TV maker seems to be extending its manufacturing capabilities to keep up with increasing market share but is there more to this...
If you missed Amazon Prime Day there are still some of great deals on SVS 16-Ultra subwoofers, Roku Pro TVs and more.
Daily Deals
Check out this limited time 33% off deal on LG's best Dolby Atmos soundbar system.
