LG StanbyME XT7S is a Portable Bluetooth Speaker and Soundbar
The LG StanbyME is portable Bluetooth speaker that also seamlessly functions as soundbar with LG’s lifestyle TV.
LG StanbyME XT7S Portable Bluetooth Speaker
LG is known for its OLED and QNED TVs, as well as its soundbar offerings, but the company has quietly been expanding its StanbyME suite of go-anywhere lifestyle products. The original StanbyME is a 27-inch rollable touchscreen display, while the StanbyME Go is an innovative 27-inch TV in a briefcase. Both work off battery power for up to 3 hours.
LG’s latest product in the range is the StanbyME Portable Bluetooth Speaker (model XT7S), which is a perfect companion to LG’s StanbyME display. Not only does it sync automatically, it can be controlled by the TV’s remote.
LG StanbyME XT7S Portable Bluetooth Speaker with Remote Control
Key Features
Pairing with StanbyME Screen: The XT7S is designed to complement LG’s StanbyME lifestyle screen, and offers easy pairing to deliver an elevated audio-visual experience.
Tip: LG has not indicated whether the XT7S can also pair with the StanbyME Go “briefcase TV”.
LG StanbyME XT7S Portable Bluetooth Speaker Drivers
WOW Orchestra: WOW Orchestra combines the XT7S speaker with the StanbyME TV screen’s built-in audio system. This creates a unified audio experience from both the speaker and TV audio capabilities working together. The α(Alpha)7 Gen 6 AI processor in the StanbyME TV optimizes sound by content type, while the StanbyME speaker delivers detailed high frequency stereo sound.
Versatile and Portable Design: The StanbyME Speaker can be used with a StanbyME TV or as a standalone portable speaker depending on your needs. With its portable size, IPX5 rating, and 16 hours of playback, take the speaker anywhere you go.
LG StanbyME XT7S Portable Bluetooth Speaker Top Rear
Specifications
  • Bluetooth App: Android/iOS (forthcoming)
  • Bluetooth Codecs: AAC and SBC
  • Onboard Playback Controls: Yes
  • WOW Orchestra: Yes
  • TV Sound Mode Share: Yes
  • EQ Settings:  EQ Default, User EQ, Sound Boost, Standard
  • Number of Channels: 1 (2-Way driver configuration)
  • Front Speaker Tweeter: 2 x 20mm
  • Woofer: 1 x Unit Track Type Woofer (42x80mm)
  • Passive Radiator: Yes
  • Total Output Power: 20W
  • Battery Play Time: Up to 16 hours
  • USB Type-C charging:  Yes
  • Battery Indicator: Yes
  • Weatherproof Rating: IPX5
  • Included Accessories:
    • Speaker Mounting Cradle
    • USB Type-C Cable
    • Wall Mount Bracket
    • Warranty Card
  • Dimensions (WxHxD): 12.9 x 3.1 x 3.4-inches
  • Net Weight: 2.2 lbs
LG StanbyME XT7S Portable Bluetooth Speaker Front
Price & Availability
LG StanbyME XT7S portable speaker is currently available $196.99 at Amazon
Tip: The LG StanbyMe Lifestyle Screen is priced at $999.99 at Amazon
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
HDTV 4K & 8K TV
DTS support has disappeared from 2025 LG TVs. Is there something else afoot to replace it that might be better?
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
HDTV 4K & 8K TV
After two years, LG dumps MLA. Find out what it is being replaced with and what it means for TV buyers
Shopping for a new TV? Our picks for best televisions of 2024 provide the best picture quality and value at their price and size.
Before you buy a 2022 4K TV this year, take a much deeper dive into what's available and worth buying.
HDTV 4K & 8K TV
At $59,999, the LG SIGNATURE OLED T is the most expensive 77-inch TV in the world. It looks like a pane of glass you...
