LG ProBeam HF80JA is Affordable 1080p Laser Projector
LG ProBeam HF80JA Laser Projector
LG Electronics USA just introduced the LG ProBeam (model HF80JA), a compact Full HD laser projector for $1500. It projects a 120-inch 1080p picture for a big home theater experience, while offering the convenience of connecting to wireless speakers or headphones for sound thanks to its Bluetooth audio out. Plus it’s lightweight and portable with Netflix, VuDu, Hulu Plus, and Youtube built-in.
It is equipped with an advanced laser engine that produces up to 2,000 lumens of brightness and features a slim, sleek design, which makes it more portable, thanks to its innovative I-shaped laser engine. Employing a compact standing-type design, the 4.6-pound LG ProBeam is one of the industry’s lightest Full HD (1920×1080) laser projectors in the brightness range of 2,000 lumens. Beyond portability, it’s nice to know the light source is expected to last 20,000 hours.
The LG ProBeam’s Wireless Mirroring feature takes advantage of Miracast to project content from smart devices onto a large projection screen. What’s more, the LG ProBeam features Wireless Content Share via the LG TV Plus App. Simply download and install the free LG TV Plus app from Google Play or the App Store on a compatible Android or iOS device, to stream videos and photos easily from a smartphone or tablet to the projector over a home network. The LG TV Plus app also includes a handy touchscreen remote control feature for convenient and easy control of the LG ProBeam.
The LG ProBeam is equipped with LG’s webOS Smart TV platform, giving consumers access to the ever-growing number of streaming services and other desired programs based on location and availability. LG’s Magic Remote Control allows for easy navigation of the webOS interface. Two USB ports are available to easily plug-in USB storage drives for on-the-go PowerPoint presentations or other media.
“Never worry about screen distortion,” says Alessi, thanks to the LG ProBeam’s vertical Auto Keystone alignment feature that automatically detects and corrects any screen image distortion for ideal projection alignment. (Manual Keystone alignment also is available for fine tuning adjustments if needed.)
Specifications
Display Type DLP
Native Resolution Full HD (1920 x 1080)
Screen Size 30″ ~ 120″
Projection Image 80″@8.1ft (40″@4.0ft)
Aspect Ratio 16:9/Just Scan/Original/ 4:3/Zoom/Cinema Zoom
Zoom x 1.1
Brightness* Up to 2,000 lumens
Contrast Ratio 150,000:1
Lamp Type Laser
Lamp Life Up to 20,000 hrs
Noise 26/28/30dB
Digital Keystone Correction Auto Keystone (Veritical), Manual 4 corner keystone
SMART TV
Premium Content Providers Netflix, VuDu, Hulu Plus, Youtube
Magic Remote Control Yes
App Store Yes
Web Browser Yes
WIRELESS
Screen Share (with Android O/S, WiDi supporting device) Yes
Wireless Contents Share (with iOS, Adroid / via TV Plus App) Yes
DLNA Yes
Bluetooth (with Speaker) Yes (AV Sync adjustable)
AUDIO
Bluetooth sound out Yes
Built-in Speakers 3W + 3W Stereo
INPUTS / OUTPUTS
HID (Keyboard/Mouse/GamePad Connection Thru USB) Yes
Digital TV Tuner Yes
Audio out 1 (3.5mm), S/PDIF 1 (Optical)
HDMI 2
USB (DivX, MP3, Photo) 2 (Type A)
RJ45 Yes
POWER
Power Supply (Voltage, Hz) 100V ~ 240V, 50/60 Hz
Power Consumption 150W (Max)
Standby Mode Less than 0.5W
Quick On/Off Yes (On in 10 seconds – Off in 2 seconds )
DIMENSIONS / WEIGHT
Product (W x D x H) 4.25″ x 9.93 x 5.51″
Shipping Dimensions (W x D x H) 12.60″ x 8.07″ x 12.95″
Weight 4.63 lbs
Shipping Weight 9.48 lbs
WARRANTY / UPC
Limited Warranty 1 Year Parts & Labor
UPC 719192608917
Price and Availability
The LG ProBeam (model HF80JA) is available now for $1,499.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
HDTV 4K & 8K TV
DTS support has disappeared from 2025 LG TVs. Is there something else afoot to replace it that might be better?
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HDTV 4K & 8K TV
At $59,999, the LG SIGNATURE OLED T is the most expensive 77-inch TV in the world. It looks like a pane of glass you...
Daily Deals
Now is the time for great deals on great-looking TVs. Here are our picks for the best Black Friday TV deals from 48 to...
Daily Deals
Our favorite soundbars on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
The Chinese TV maker seems to be extending its manufacturing capabilities to keep up with increasing market share but is there more to this...
If you missed Amazon Prime Day there are still some of great deals on SVS 16-Ultra subwoofers, Roku Pro TVs and more.
Daily Deals
Check out this limited time 33% off deal on LG's best Dolby Atmos soundbar system.
