Laptops
LG P420 Notebook PC
LG Electronics (LG) just unveiled the 14-inch P420 premium notebook, featuring a sleek outer case and streamlined style for a modern look.
The P420, a 14-inch version of the P210, will be powered by 8GB of memory and the forthcoming, 2nd generation Intel Core i5 processor. It also boasts a crisp, high-quality HD display thanks to an NVIDIA GeForce GT520M graphics card.
By bringing the screen right to the edges of the notebook, the wafer-thin bezel provides users with a wider-screen on a compact body. With its slim-edge bezel, the P420 packs a deceptively large, 14-inch screen on 13.3-inch-wide device. A crystal clear HD LED LCD display adds to the enjoyment by bringing TV-standard graphics onto a notebook screen.
Specifications P420
Processor 2nd Gen. Intel Core i5 Processor
Operating System Windows 7 Home Basic (32/64-bit)
Windows 7 Home Premium (32/64-bit)
Windows 7 Professional (32/64-bit)
Display 14″ HD (1366 x 768) LED LCD
Memory Max. 8GB
Graphic Intel HD Graphics
NVIDIA GeForce GT 520M 1G / 512M (Optimus)
Storage HDD Max. 320GB
Ethernet Gbit LAN
Wi-Fi 802.11bgn/agn
Bluetooth 3.0+HS
Audio Stereo Speaker with SRS TruSurround HD
Multi Media Card 7-in-1 (xD, MMC, SD, SDHC, SDXC, MS, MS Pro)
Input / Output Port HDMI (ver. 1.4), USB (x3), HP Out, Mic In, Int. Mic, VGA, RJ45, DC-In
LG Software LG Smart Software,LG Media Funtasia
Speciality Noise Reduction Technology (21 dB)
Dimensions 333mm x 221mm x 25.9 ~31.5mm
Weight 1.98kg
Design Minimalistic Design with Slim Edge Bezel
Availability
Available worldwide in the first quarter of 2011. Check price.
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
