LG Optimus Vu 4G LTE Smartphone
LG announced the Optimus Vu, a LTE smartphone with large 5-inch IPS display. The device offers a unique combination of tablet-like viewing with smartphone portability, which runs on a powerful 1.5GHz dual-core processor, 32GB internal memory and a large 2,080 mAh battery.
The large 5-inch display with bright 4:3 aspect ratio makes viewing documents, books, internet and multimedia contents easier and more comfortable. The 4:3 aspect ratio is optimized for viewing to grasp more at a glance and note taking to increase productivity in everyday life. Moreover, IPS display realizes every color in its natural state for the best viewing experience even under bright sunlight.
Backed by unparalleled speed and performance from LG's advanced LTE technology, the Optimus Vu: boasts unmatched productivity. Its unique built-in QuickClip hotkey allows users to conveniently capture screenshots and memos with a single push. Jotting notes is also possible with a finger or with the dedicated Rubberdium pen. Among many productive apps installed in the Optimus Vu:, the included Polaris Office allows users to open any document, spreadsheet or presentation while on the go.
At only 8.5mm, the Optimus Vu: is the slimmest among all 4G LTE phones currently on the market and is perfectly suited for a hand and fits comfortably in a jacket pocket. Despite the large 2,080mAh battery, the Optimus Vu: adopts LG's exclusive floating mass technology to appear slimmer than its actual dimensions.
LG Optimus Vu 4G LTE Smartphone - Back
In addition to HDMI (High Definition Multimedia Interface) and DLNA (Digital Living Network Alliance), Optimus Vu: comes with 32GB memory and an 8-megapixel camera. While it will initially launch running Android 2.3 Gingerbread, an update to Android 4.0 Ice Cream Sandwich is already in the works.
Availability
The LG Optimus Vu will be introduced in Korea in March 2012. Check price →
Key Specifications:
  • Chipset: 1.5GHz Dual-Core Processor
  • Display: 5-inch (1024×768) IPS Display
  • Memory: 32GB eMMC and 1GB DDR2
  • Camera: 8MP with AF LED Flash (rear) and 1.3MP (front)
  • OS: Android 2.3 Gingerbread
  • Battery: 2,080mAh
  • Dimension (L x W x D): 139.6 x 90.4 x 8.5mm
Which TVs are worth buying in 2026? Our hands-on tested Editors’ Choice winners cut through the hype to reveal the best OLED, Mini LED...
LG's flagship soundbar, the Sound Suite H7, just got support for DTS:X surround, but good luck making that work on an LG TV.
Gadgets
Apple's $299 HomeView leads a new smart home lineup with Siri AI, security cameras, smart locks and thermostats. Can Apple finally simplify the connected...
Available only in 77-inch or 83-inch sizes, LG's upper mid-range OLED TVs for 2026 offer key features found in its flagship OLED models.
LCD panel costs are rising for Samsung, LG and Sony as Chinese suppliers cut production just as cheaper OLED TVs narrow the price gap.
The blog DoctorBeet uncovered a disturbing problem with some LG Smart TVs on November 18, 2013. All viewing habits were being to sent to LG’s...
Podcasts
eCoustics video experts reveal their favorite TVs of 2026, including a value pick that might surprise you.
