Mouse
LG LSM-100 Mouse Scanner
LG Electronics introduced the LSM-100 mouse with a built-in scanner, offering an array of unique functions that blend surprising innovation and user convenience.
Operating the LSM-100's scanning function is far more convenient than on conventional scanners. While holding the Smart Scan button on the left side of the mouse, the user simply swipes the mouse over the material to be scanned. The scanned image can then be saved in a variety of file types — PNG, JPEG, TIFF, BMP, PDF, XLS and DOC — or dragged and dropped into the desired application.
The LSM-100 Smart Scan is also equipped with LG's Optical Character Recognition technology, which converts scanned text into a Microsoft Word document that can then be edited and manipulated as the user sees fit. By eliminating the need to retype text from print media onto the screen, Optical Character Reader saves users a great deal of time.
The mouse's compact size belies its big-sized capabilities. Because it's not limited by a frame, the LSM-100 can scan page sizes up to A3, larger than most conventional portable scanners. Additionally, the scanning technology itself has been upgraded to handle faster pass-over rates, meaning that scanning an A3 sheet can be done smoothly and quickly.
The LSM-100 is also an accurate and durable laser mouse in a stylish design that lends itself to easy, smooth motions as well as providing an ergonomic, comfortable grip.
Price and Availability
The LG LSM-100 is currently available for £89 at Amazon UK.
See more about: LG, Mouse, Scanners
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
