LG HU85LA CineBeam 4K Laser Projector Sits Pretty
Short-throw 4K laser projector displays a 90-inch image when placed on a tabletop just 2.2-inches from the wall.
LG HU85LA CineBeam 4K Short-Throw Projector
Projects Massive Screen Only 2.2-inches From Wall
LG Electronics just released the HU85LA 4K UHD Laser Smart Home Theater CineBeam Projector for $5,999. That is a long name for short-throw projector that simplifies a front projection installation, since it need only sit 2.2-inches from the wall. At that distance it projects a massive 90-inch image, but with a little more space (7.1-inches) the screen jumps to 120-inches in diagonal.
LG HU85LA CineBeam Short-Throw 4K UHD Laser Projector
Housed in an extreme minimalist design, the LG CineBeam 4K laser projector includes HDR10 high dynamic range capability to deliver far deeper blacks in dark scenes and more life-like bright highlights, meticulously displaying the content as originally intended by the content creators. It also features IP Control with Control4, Crestron, and Savant.
LG HU85LA 4K UHD Laser Smart Home Theater CineBeam Projector
The LG HU85LA projector can simply be placed on a table top or optionally mounted on the ceiling. It also the first projector to have both the Google Assistant and LG ThinQ AI solution built in, allowing for seamless control and content discovery through simple voice commands. No additional device is needed to use the Google Assistant. Furthermore, LG’s smart TV platform enables Netflix, YouTube and Amazon streaming without a set-top box.
LG HU85LA Projector - Back View
The LG HU85LA projects up to a 120-inch diagonal 4K image and its 2,700 ANSI lumens deliver a clear and vivid picture, even in higher ambient light conditions. Unlike conventional projectors that use a blue laser and color wheel, this new ultra short throw 4K projector employs a new optical system that uses a three-channel laser for the separate RGB primary colors, ensuring vivid color reproduction without color loss.
Remote Control for LG HU85LA Projector
The included LG Magic Remote is also the world’s first to be able to implement both motion-based user interface and backlit functions, ensuring the optimized handling of the projector with smart features.
Price & Availability
The LG HU85LA CineBeam 4K Laser Projector is available now for $5,999 at at LG-authorized dealers nationwide (released July 2019).
Which TVs are worth buying in 2026? Our hands-on tested Editors’ Choice winners cut through the hype to reveal the best OLED, Mini LED...
LG's flagship soundbar, the Sound Suite H7, just got support for DTS:X surround, but good luck making that work on an LG TV.
Gadgets
Apple's $299 HomeView leads a new smart home lineup with Siri AI, security cameras, smart locks and thermostats. Can Apple finally simplify the connected...
Available only in 77-inch or 83-inch sizes, LG's upper mid-range OLED TVs for 2026 offer key features found in its flagship OLED models.
LCD panel costs are rising for Samsung, LG and Sony as Chinese suppliers cut production just as cheaper OLED TVs narrow the price gap.
The blog DoctorBeet uncovered a disturbing problem with some LG Smart TVs on November 18, 2013. All viewing habits were being to sent to LG’s...
Podcasts
eCoustics video experts reveal their favorite TVs of 2026, including a value pick that might surprise you.
