LG G3 Smartphone
LG G3 Smartphone
LG Electronics today released the G3 Android global smartphone, developed under the Simple is the New Smart concept. The 5.5-inch screen sized phone offers double the resolution of Full HD displays with 538ppi. The G3 utilizes a floating arc form factor that feels incredibly comfortable in one hand and incorporates the innovative design heritage of the rear key, plus a redesigned graphic user interface.
The G3’s advanced 13-megapixel OIS+ camera is designed to quickly and easily capture life’s special moments as they occur, not necessarily when you want them to occur. This is made possible with G3’s innovative Laser Auto Focus, the first of its kind in the smartphone industry. This technology enables the G3 to capture the best moment — even in low light — by measuring the distance between the subject and the camera using a laser beam. So no more fuzzy pictures of your son scoring his first football goal and or missed shots because your camera couldn’t decide quickly enough which toddler in the playground to focus on. Combined with the proven and popular OIS+ technology first seen in the G Pro 2, the G3 is sure to impress even the most discerning shutterbugs.
LG also simplified the process of actually capturing those special moments. Rather than having to focus on the subject in preview mode and then pressing the shutter button, with the G3, tapping the subject to focus will simultaneously also trigger the shutter. What’s more, the G3’s 2.1-megapixel front camera incorporates several new enhancements such as a larger image sensor and larger aperture for more light throughput and better-looking selfies. A unique twist has been added to the standard timed selfie mode by incorporating gesture controls — when ready to shoot, simply clench your hand into a fist and the G3 will recognize the gesture and begin the automatic three-second countdown. It couldn’t get any simpler than that.
LG G3 smartphone colors
For video, the G3 offers superior sound quality with instinctive microphones that measure the environment to identify the optimal audio level for the clearest recording. And with the built-in 1W speaker with Boost AMP, users can enjoy videos and music accompanied by richer sounds and clearer tones.
LG G3’s Quad HD display offers a pixel density of 538ppi, setting a new viewing standard, producing images that are sharper and clearer than traditional smartphone displays. At 5.5-inches, LG G3 boasts a screen ratio of 76.4 percent with thin bezels all around so the phone feels as comfortable in the hand as a smaller traditional smartphone.
LG equipped the G3 with a 3,000mAh removable battery and advanced optimization technologies to further maximize battery efficiency. By replacing the metal in the battery cathode with graphite, LG engineers were able to extend the lifespan of the G3’s battery. The result is a battery that can keep up with the Quad HD display’s ultra-high performance without losing steam in the middle of the day.
The Floating Arc design of the G3 with its ergonomic arch and slim side profile provides an extremely comfortable grip for everyday one-handed use. The Rear Key continues to anchor LG’s innovative design language, with a newly designed power key and volume buttons as well as more premium quality materials and finish. LG also refined sophisticated technical features and advancements located on the rear by arranging them in a clean and singular layout consistent with the G3’s well-balanced design language. The stylish metallic skin with matte finish which keeps the G3 looking clean and fingerprint-free will be offered in five vibrant colors: Metallic Black, Silk White, Shine Gold, Moon Violet and Burgundy Red.
LG G3 front back
To complement the new external design, LG adopted a minimalistic user interface design with flat graphics. The circular motif of the graphic assets in the new UI was derived from the shape and concept of LG’s logo, reflecting its unique visual style and identity.
Simplified UX Features:
  • Smart Keyboard: Adaptive technology learns as you type for faster input with less mistakes. Smart Keyboard reduces input errors by up to 75 percent by tracking and analyzing typing habits and intuitively “knowing” what word the user intended to type. The height of the keyboard can also be adjusted to better fit the user’s hands and position of the thumbs. Individual keys can also be customized with frequently used symbols for even faster input.
  • Smart Notice: Like a personal assistant, Smart Notice provides suggestions and recommendations based on user behavior, phone usage patterns and location to offer user information when it’s needed the most. Smart Notice can remind you of a call you declined earlier and ask if you would like to call that person back. If you have a large number of un used files or apps on the G3 taking up valuable space, Smart Notice will ask if you would like to delete or uninstall them. But what sets Smart Notice apart from other personal assistants is its natural language capabilities. For example, instead of just displaying today’s temperature and weather forecast, Smart Notice will make a recommendation such as, “You may want to take an umbrella today since it will rain this evening.”
  • Smart Security: Understanding the importance of maintaining and securing confidential data when smartphones are shared, misplaced, lost or stolen, the LG G3 offers a number of enhanced security features such as:
    • Knock Code enables users to unlock their device with a pattern of taps. Merging security and convenience, users can create a personalized code that can be entered anywhere on the screen. With the G3, users have the option of being able to use KnockON to wake the screen to check the time as well as enter the home screen directly via Knock Code.
    • Content Lock keeps personal files safe and hidden from view when sharing the G3 with friends. When the G3 is connected to a PC, Content Lock prevents file previews so the data is still safe. The locked files can reside either on the G3’s internal memory or on the microSD card.
    • Kill Switch gives G3 owners the ability to disable their phones remotely in the event of theft. The Kill Switch also allows content on the G3 to be wiped so personal information won’t be compromised. Kill Switch also includes antivirus scanning and remote wipe and lock, among other essential features.
LG will also be offering a collection of new premium accessories to accompany the LG G3:
  • QuickCircle Case: Available in five colors, QuickCircle Case allows easy access to frequently used functions such as calling, text messaging, music and camera all from the QuickCircle window without opening the cover. In addition to the QuickCircle Case, LG will offer a lineup of Slim Guard Cases and premium Slim Hard Cases to protect the G3 in handsome style.
  • LG Tone Infinim (HBS-900): Developed in collaboration with Harman/Kardon, the Bluetooth stereo headset delivers premium audio quality sound in a stylish design. Built with retractable wire management technology and jog buttons for effortless search, Tone Infinim also features Name Alert to verbally notify you who is calling before you answer.
  • Wireless Charger: Compact and foldable, LG’s Wireless Charger is optimized for easy portability. Compatible with Qi’s wireless power charging technology, the Wireless Charger from LG makes staying powered up as convenient as possible.
https://www.youtube.com/watch?v=T_km8oZ2g98
Price and Availability
Starting on May 28, 2014 in South Korea, LG G3 will begin rolling out worldwide on over 170 carriers. Additional details will be announced locally at the time of availability.
Key Specifications:
  • Chipset: Qualcomm Snapdragon 801 (up to 2.5GHz Quad-Core)
  • Display: 5.5-inch Quad HD IPS (2560 x 1440, 538ppi)
  • Memory: 16/32GB eMMC ROM, 2/3GB DDR3 RAM / microSD slot (128GB max)
  • Camera: Rear 13.0MP with OIS+ and Laser Auto Focus / Front 2.1MP
  • Battery: 3,000mAh (removable)
  • Operating System: Android 4.4.2 KitKat
  • Size: 146.3 x 74.6 x 8.9mm
  • Weight: 149g
  • Network: 4G / LTE / HSPA+ 21 Mbps (3G)
  • Connectivity: Wi-Fi 802.11 a/b/g/n/ac, Bluetooth Smart Ready (Apt-X), NFC, SlimPort, A-GPS/Glonass, USB 2.0
  • Color: Metallic Black, Silk White, Shine Gold, Moon Violet, Burgundy Red
  • Other: Smart Keyboard, Smart Notice, Knock Code, Guest Mode, etc.
* Specifications may vary depending on the market.
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
HDTV 4K & 8K TV
DTS support has disappeared from 2025 LG TVs. Is there something else afoot to replace it that might be better?
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HDTV 4K & 8K TV
At $59,999, the LG SIGNATURE OLED T is the most expensive 77-inch TV in the world. It looks like a pane of glass you...
Daily Deals
Now is the time for great deals on great-looking TVs. Here are our picks for the best Black Friday TV deals from 48 to...
Daily Deals
Our favorite soundbars on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
The Chinese TV maker seems to be extending its manufacturing capabilities to keep up with increasing market share but is there more to this...
If you missed Amazon Prime Day there are still some of great deals on SVS 16-Ultra subwoofers, Roku Pro TVs and more.
Daily Deals
Check out this limited time 33% off deal on LG's best Dolby Atmos soundbar system.
