LG CineBeam PF510Q FHD LED Projector Unveiled
The LG CineBeam PF510Q offers native 1080p resolution, a long-lasting LED light source, smart TV features, and portability.
LG PF510Q Smart Portable Projector Front
Although known primarily for its OLED TVs, LG also offers up a line of video projectors, ranging from inexpensive portables to expensive USTs (Ultra Short Throw 4K Laser Projectors). In this article, we take a look at their most recently released compact portable projector, the CineBeam PF510Q.
The LG CineBeam PF510Q is a projector that can be used at home or on the go.  With 1080p native resolution and built-in smart TV streaming features, you don’t need to plug anything else (although you do have that option) to start watching, just connect it to the internet.
LG PF510Q Portable Projector Front Angle
LED Light Source
The CineBeam PF510Q incorporates a 4-channel LED light source. One LED emits red light, one green, one blue, and a fourth emits what is referred to as Dynamic (contains elements of green and blue). The red, green, blue, and dynamic green light travels through a lens and prism and are bounced off a DLP Chip and then to the screen.
Four advantages of an LED light source over a lamp in a projector are:
  • LEDs are smaller than lamps, which is more practical than smaller projectors.
  • LEDs don’t have to be replaced periodically, making the system very cost-effective.
  • LED lights run cooler than traditional lamps so the need for a large noisy fan is lessened.
RGB LED Colors
DLP Imaging Chip with FHD (1080p) Resolution
In addition to the LED light source which facilitates color, the grayscale image information is provided by a DLP imaging chip (aka DMD – Digital Micromirror Device) from Texas Instruments.
The DLP chip has 2.1 million pixels (1080p FHD resolution), which are very tiny mirrors that angle back and both very rapidly to produce the light and dark parts of the image in combination with the reflected LED light source that adds the color.
In addition to the technologies used to project the image onto a screen or wall, here are the PF510Q’s additional features and specifications.
LG PF510Q Portable Projector with WebOS 22
LG WebOS ver 22
  • Light Output: 450 ANSI Lumens Max (works best in a darkened room or outside at night)
  • Light Source Life: Up to 30,000 hours
  • Contrast Ratio: 150,000:1
  • HDR Compatibility: HDR10 (Keep in mind that with its modest lumens output, the HDR effect will be minimal)
  • Refresh Rate: Not stated, but most likely 60Hz with possible added motion processing.
  • Screen Size: 30 to 120-inches
  • Projection Distance: 60-inches at 5.2ft, 100-inches at 8.7ft
  • Optical Zoom: Fixed
  • Focus: Manual
  • Throw Ratio: 1.2
  • Keystone Correction: Vertical
  • Audio System: 5 watts (mono)
  • Audio Formats: Dolby Audio (includes Dolby Atmos pass-through via HDMI-ARC).
  • Smart TV: LG WebOS ver 22. Access is provided for streaming apps such as  Disney+, YouTube, Prime Video, and  Apple TV+. More can be installed on the projector via the built-in LG Content Store or cast from compatible smartphones. A Web browser is also included.
  • Control: LG remote control provided, Joystick control on the projector if needed.
LG PF510Q Portable Projector Remote
Input Connections
  • HDMI ver 2.0 (2 – 1 supports HDMI-ARC)
  • USB ver 2.0  (1) with support for Keyboard, Mouse, and Game Controller connection in addition to media file playback.
  • Ethernet/LAN (1)
Output Connections:
  • 3.5mm analog headphone output (1)
LG PF510Q Portable Projector Rear Angle
Additional Connectivity
  • Wi-Fi
  • Screen Share (Miracast/Screen Mirroring)
  • Content Share via DLNA
  • Apple Airplay 2
  • Bluetooth Dual Output
LG PF510Q Portable Projector Dual Bluetooth
LG PF510Q Portable Projector Screen Mirroring
  • Fan Noise (Eco / Normal / High Brightness): 24 / 26 / 29 dB
  • Dimensions (WHD): 5.8 x 7.6 x 5.8-inches
  • Weight: 2.2 lbs
  • Expected Lifespan: 30,000 use hours
Pricing and Availability
The LG CineBeam PF510Q Projector has a suggested price of $599.99 and is available from LG.com (Amazon coming soon).
Tip: Travel bag not included – shown for illustration of projector size and portability.
LG PF510Q Portable Projector in Travel Case
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
DTS support has disappeared from 2025 LG TVs. Is there something else afoot to replace it that might be better?
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
Sister Company to UST Projector Maker AWOL, Valerion has a line of standard throw projectors that might be just right for you
HDTV 4K & 8K TV
After two years, LG dumps MLA. Find out what it is being replaced with and what it means for TV buyers
Shopping for a new TV? Our picks for best televisions of 2024 provide the best picture quality and value at their price and size.
Before you buy a 2022 4K TV this year, take a much deeper dive into what's available and worth buying.
HDTV 4K & 8K TV
At $59,999, the LG SIGNATURE OLED T is the most expensive 77-inch TV in the world. It looks like a pane of glass you...
