HDTV 4K & 8K TV
LG’s 97M3 97-inch Zero Connect Wireless OLED TV is Finally Shipping
First shown at CES 2023, the LG 97M3 Wireless OLED TV with Zero Connect Technology is finally shipping, but only in South Korea.
LG Signature 97M3 Wireless OLED TV Debut at CES 2023
We first saw the LG 97M3 with Zero Connect Technology at the 2023 CES where it was displayed prominently at the LG booth; the CES 2023 Innovation Award winning TV impressed attendees for both its excellent image quality and innovative design.
After almost 6 months of waiting, LG has finally begun to ship the 97-inch M3 as part of its SIGNATURE OLED TV line. The 97M3 is currently available in South Korea, with plans for a global rollout to key markets including North America and Europe later this year.
November 2023 Update: The LG 97M3 is now available for in the U.S. for $29,999.
LG Signature 97M3 Wireless OLED TV with Zero Connect Box
LG Signature M Series OLED TV Recap
The LG Signature M Series OLED TV is the world’s first consumer TV with Zero Connect technology. This feature provides real-time wireless video and audio transmission at up to 4K @ 120Hz. The 97M3 delivers superior picture and sound quality as well as greater flexibility to install and connect.
Tip: What is an OLED TV?
Zero Connect technology eliminates the need to have cables and devices in close proximity to the screen. This means less clutter because all of your source devices connect to the included Zero Connect Box (which can be placed anywhere in your viewing room and transmits the signals to the built-in receiver in the 97M3’s 97-inch 4K UHD OLED display panel.
LG Zero Connect Box
Tip: The Zero Connect Box has a 10-meter transmission distance. The box identifies the optimal transmission path and has an adjustable antenna that can be positioned according to the screen’s location.
The Zero Connect Box includes a full range of connection options including HDMI 2.1, USB, RF, LAN, and Bluetooth.
LG Zero Connect Box Back
LG’s proprietary wireless transmission technology supports large amounts of data at up to 3 times the speed of the existing Wi-Fi 6E standard. Wireless transmission of Dolby Vision and Dolby Atmos is also supported.
As part of LG’s SIGNATURE Series TV products, the OLED M series has an ultra-modern Gallery Design, which provides a seamless, flush-to-wall mount. Users can effectively eliminate the need to place a cabinet or table directly near the TV.
LG Signature 97M3 Wireless OLED TV Corner
The LG M utilizes an LG Evo OLED panel and includes all of the video processing, smart features, user navigation, and gaming support as other LG OLED TVs (reportedly the same as the G3 series).
Tip: It is expected that the M3 will not include LG’s latest OLED Meta technology
Availability and Pricing
Nov. 2023 Update: The LG M3 Wireless 97-inch OLED 4K TV (model OLED97M3PUA) is available for $29,999 at LG, Best Buy and Amazon.
83-inch ($7,999) and 77-inch ($4,999) models are also available from the links above.
LG Signature 97M3 Wireless OLED TV Side with Stand
Tip: Although the LG SIGNATURE M Series TV is labeled as wireless, it still has power cords for both the display and Zero Connect Box. If you want a truly wireless TV, check out our report on Displace TV.
For more information: LG Product Page
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
DTS support has disappeared from 2025 LG TVs. Is there something else afoot to replace it that might be better?
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
HDTV 4K & 8K TV
After two years, LG dumps MLA. Find out what it is being replaced with and what it means for TV buyers
Shopping for a new TV? Our picks for best televisions of 2024 provide the best picture quality and value at their price and size.
Before you buy a 2022 4K TV this year, take a much deeper dive into what's available and worth buying.
HDTV 4K & 8K TV
At $59,999, the LG SIGNATURE OLED T is the most expensive 77-inch TV in the world. It looks like a pane of glass you...
Daily Deals
Now is the time for great deals on great-looking TVs. Here are our picks for the best Black Friday TV deals from 48 to...
