HDTV 4K & 8K TV
LG Announces New 49-inch UltraGear 32:9 Curved Screen Gaming Monitor for 2023
The LG 49GR85DC-B UltraGear Widescreen Monitor elevates the gaming experience with advanced features and picture quality.
LG 49GR85DC-B 49-inch Curved UltraGear Gaming Monitor
In September 2022, LG unveiled its most innovative gaming monitor yet with the LX3 which featured a bendable 4K UHD OLED screen and both gaming and smart TV features.
The LX3 is still an active part of the LG’s line-up, but for 2023 they are adding another option for serious gamers, the UltraGear 49GR85DC-B dedicated gaming monitor.
What makes this entry different from the LX3 is that the smart TV features are stripped out and instead of a 42-inch 16×9 aspect ratio bendable OLED screen, the 49GR85DC-B has a 49-inch permanently curved ultra-wide 32:9 aspect ratio LED/LCD screen with Dual QHD resolution (5129×1440 pixels).
Tip: Read our article: WTF is Aspect Ratio?
LG 49GR85DC-B 49-inch Curved Gaming Monitor Desktop Setup
The monitor has a virtually borderless, display design and LED Hexagon backlighting. Plus, one can easily make height, tilt, and swivel adjustments to the display to be able to see and play exactly to your preferences.
The 49GR85DC-B’s Gamer-Centric Design is designed to provide an immersive gaming experience.
Under The Hood
In addition to its physical design here is an overview of its “under-the-hood” features.
LG 49GR85DC-B 49-inch Curved Gaming Monitor Picture in Picture
Picture in Picture/Picture by Picture: This feature provides Picture-in-Picture (PiP) and Picture-by-Picture (PbP) screen display. This allows users to configure the monitor to display content from two separate input sources. Play, watch, stream, or work from multiple input sources at the same time, on one screen.
LG 49GR85DC-B 49-inch Curved Gaming Monitor Game GUI
Enhanced Gaming GUI: The onscreen interface provides access to several viewing modes that help to optimize the gameplay. Modes include Gamer, FPS (first-person shooter), or RTS (real-time strategy).
LG 49GR85DC-B 49-inch Curved Gaming Monitor with 1ms Response Time
Dynamic Action Sync: Enables users to respond to the action in real-time with reduced input lag. The 49GR85DC-B has a 0.1 millisecond response time.
Black Stabilizer: This optimizes shadow detail so you can better see objects hidden in dark areas.
FPS Counter: Frames per second are displayed for real-time data.
Crosshair: Center-display crosshairs are included. This provides enhanced vision and pro-level precision for increased gameplay accuracy.,
LG 49GR85DC-B 49-inch Curved Gaming Monitor VESA HDR1000
VESA DisplayHDR™ 1000: This feature provides the capability to display impressive peak brightness and exceptional color and contrast for HDR gaming. HDR10 is also supported.
240Hz Refresh Rate: This provides a smooth display of fast motion. This allows you to respond quickly to opponents and stay a step ahead of the competition.
LG 49GR85DC-B 49-inch Curved Gaming Monitor and Freesync Premium Pro
AMD FreeSync™ Premium Pro: This provides access to a fluid, virtually tear-free gaming experience. With support for at least 1080p/120Hz and low latency gameplay.
DisplayPort or HDMI: With both HDMI 2.1 and DisplayPort 1.4 (your choice depending on the source) you can experience up to 240Hz refresh rate at DQHD (Dual Quad HD) resolution.
DTS® Headphone:X: This feature provides accurate spatialization and localization in games for 3D audio over headphones. Supports channel-based, scene-based, and object-based audio.
4-pole Headphone Jack: In addition to DTS Headphone:X, the provided 4-pole headphone jack enables users to use a stereo headphone signal and mono microphone signal with common ground.
Tip: The 49GR85DC-B does not have built-in speakers.
LG 49GR85DC-B 49-inch Curved Gaming Monitor Front Back
Pricing & Availability
The LG 49GR85DC-B 49-inch Curved UltraGear Gaming Monitor is now available for preorder for $1,299.99 exclusively at LG.com thru April 2, 2023.
Special Offer: If you pre-order the 49GR85DC-B you will also get a free UltraGear™ Gaming Pad ($199.99 value).
Pre-orders are expected to ship in early April 2023.
1 Comment
1 Comment
  1. ORT
    March 23, 2023 at 12:05 am
    Nice. As a fan of Todd AO and the owner of a 55 inch Samsung Curved UHDTV for several years now I can readily opine sans whine on the wonder and beauty of a Curved TV and moan their slow passing.
    Apparently gamers enjoy them too. I envy them.
    Thank you for the heads up!
    ORT
LG G5 OLED TV Lifestyle
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HOUCHMAND M1 System Lifestyle Image HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
JADIS JS2 SL DAC Front Angle Top Open JADIS JS2 SL DAC Front Angle Top Open
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
HDTV 4K & 8K TV
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
HDTV 4K & 8K TV
After two years, LG dumps MLA. Find out what it is being replaced with and what it means for TV buyers
Monitors
LG previews both curved and bendable OLED gaming monitors for 2025 in sizes up to 45-inches with 5K resolution and 21:9 aspect ratio.
Shopping for a new TV? Our picks for best televisions of 2024 provide the best picture quality and value at their price and size.
Before you buy a 2022 4K TV this year, take a much deeper dive into what's available and worth buying.
HDTV 4K & 8K TV
At $59,999, the LG SIGNATURE OLED T is the most expensive 77-inch TV in the world. It looks like a pane of glass you...
Daily Deals
Now is the time for great deals on great-looking TVs. Here are our picks for the best Black Friday TV deals from 48 to...
