Lexicon Displays Flagship RV-8 A/V Receiver
CEDIA EXPO, INDIANAPOLIS, IN, September 10, 2004 — Lexicon, Inc., a Harman International company (NYSE: HAR), is exhibiting the new RV-8 Receiver, an eight-channel audio/video control center with independent zone monitoring that provides control of audio and video source selection in three zones. Building on its authority as a pioneer in the upper echelon of home theater technologies, Lexicon has engineered the RV-8 to adhere to the most critical standards of quality and performance. This flagship receiver is optimized to serve as the cornerstone of an ideal home theater experience in an integrated package.
The RV-8 represents another evolutionary leap in home entertainment, yielding uncompromising audio and video playback with a wealth of features developed to answer the demands of enthusiasts and audiophiles alike. Created to match the innovative industrial design of Lexicon’s award winning home theater products, the RV-8 includes eight configurable inputs, and a built-in tuner. Inputs comprise eight digital audio, eight analog audio, one phono, five composite video, five S-video, and three component video inputs. The analog connectors can be configured for up to two 5.1-channel sources. In addition, RV-8 comes with an intuitive pre-programmed/learning IR Remote Control that provides full operation of the unit, performing commands such as menu navigation that are not available from the front panel. The Remote can also provide complete control over the entire audio/video system.
The RV-8 Receiver — Separates in an Integrated Package
The RV-8 has an integrated seven-channel power amplifier that is designed to achieve high power levels and unprecedented performance. Equipped with an enormous toroidal power transformer, the amplifier also includes thermal and DC protection. The AM/FM stereo tuner allows for the automatic or manual storing of up to 40 preset stations, and is fully configurable for ease of operation.
Featuring an expandable design for future upgrades when available, the RV-8’s rear panel has two RS-232 connectors; one capable of performing configuration downloads and flash memory software upgrades and the other capable of supporting possible future product enhancements. The rear panel also includes a removable access panel to accommodate new connectors, should Lexicon decide to offer them.
Further extending its capabilities, the RV-8 offers the latest version of Lexicon’s critically acclaimed LOGIC7 decoding, which creates a 7.1-channel output signal from stereo, 5.1- and 6.1-channel sources. Unlike other decoders, LOGIC7 decoding is compatible with all input sources and requires no special encoding. LOGIC7’s functional ingenuity is instantly recognizable, which has led to its regard as the consummate surround decoder. A LOGIC7-encoded downmix of multi-channel source material is also available when using the Headphone listening modes. If a stereo source is present, the HEADPHONE L7 listening mode processes it using LOGIC7, then uses Head Related Transfer Functions to create a headphone output that introduces a subtle sense of surround sound, while preserving the original stereo image.
In addition to LOGIC7, the RV-8 offers a host of today’s most popular audio and video playback formats with support for Dolby Digital Surround EX, Dolby Pro Logic II, DTS 96/24, DTS-ES, DTS neo:6, THX Ultra2, and THX Surround EX decoding.
With two Hammerhead Digital Signal Processing (DSP) engines, the RV-8 boasts enormous processing power. These powerful processors perform custom Lexicon processing such as LOGIC7 decoding, bass enhancement, dialog enhancement, auto azimuth, five-speaker enhancement, bass management, high-precision digital crossovers, and audio controls. These features are available at sample rates up to 96 kHz, with 24-bit resolution to retain top performance from all sources. In addition, a third DSP engine is dedicated to decoding multi-channel compressed audio sources.
The RV-8 is one of the most advanced audio and video control centers available. High-precision 24-bit/96 kHz A/D converters can be used to convert stereo analog audio input signals to digital signals, allowing the RV-8 to realize the advantages of exceptional digital signal processing without sacrificing signal integrity. 24-bit/192 kHz D/A converters are utilized for all output channels. Alternatively, 5.1-channel and stereo analog signals can bypass A/D conversion and internal processing, allowing a pure analog signal path from input to output.
Digital audio input signals are processed through a two-stage phase lock loop for extremely low intrinsic jitter and high jitter rejection. Lexicon’s proprietary Auto Azimuth Technology corrects timing and level imbalances in stereo sources, ensuring exceptionally accurate playback of surround-encoded sources. A digital audio pass-through output is available for recording digital signals with a CD recorder or similar component.
The RV-8 — Technologically Advanced Video Conversion
Complementing its audio performance, the RV-8 features two broadcast-quality video switchers. A wide-bandwidth component video switcher accepts analog component or RGB High Definition TV (HDTV), Enhanced Definition TV (EDTV), and Standard Definition TV (SDTV) video signals, while a composite and S-video switcher accepts high-quality SDTV video signals. Composite and S-video inputs can be converted to SDTV component video output. Both switchers are designed to pass video signals without alteration or degradation.
Built to the highest standards, the Lexicon RV-8 Receiver has a lengthy feature set that includes:
• 8 channels
• 8 configurable inputs
• 3 independent zones
• Integrated 7-channel amplifier with thermal/DC protection and toroidal power transformer
• AM/FM stereo radio tuner
• Phono input with 2-channel analog bypass path
• Up to two 5.1-channel analog audio input connections
• Analog bypass option for 5.1 analog and stereo audio inputs
• Auto switching between digital and analog audio inputs
• Headphone output with LOGIC7 processing
• Two 32-bit DSP engines for custom processing
• Separate DSP engine for decoding compressed audio sources
• 4 coaxial and 4 S/PDIF optical (Toslink) digital audio inputs
• 1 coaxial and 1 S/PDIF optical (Toslink) digital audio output connectors
• 24-bit/192 kHz D/A converters for all audio channels
• 2 sets of analog A/V Zone 2 outputs; 1 fixed, 1 variable
• 1 set of analog audio Zone 3 outputs, variable level
• Broadcast-quality video switching
• Video up conversion from S-video/composite input to component video output
• 3 component video inputs with full HDTV compatibility
• 5 composite video inputs
• 5 S-video inputs
• 1 component video output
• 4 S-video output connectors
• 5 composite video output connectors
• LOGIC7 decoding
• Dolby Digital Surround EX, Dolby Pro Logic II, and Dolby Pro Logic decoding
• DTS 96/24, DTS-ES (discrete and matrix), and DTS neo:6 decoding
• THX Ultra2 and THX Surround EX decoding
• THX Ultra2 certification
• Flash memory software upgrade capabilities
• 2 internal expansion slots for possible future developments
• RS-232 control
• Rear-panel IR input connector
• 2 trigger output connectors
• Optional 19-inch rack-mount kit
• IR pre-programmed/learning remote control with LCD display
The Lexicon RV-8 Receiver comes with a three-year warranty and joins Lexicon’s renowned line of home theater products, which includes: the MC-12 and MC-8 Digital Controllers; RT-10 Universal DVD/SACD Disc Player; and LX and CX Multi-channel Power Amplifiers.
Lexicon, founded in 1971, is one of the world’s premier manufacturers of home theater electronics. Innovative technologies, such as LOGIC7, have helped Lexicon to push the boundaries of home entertainment. Lexicon audio systems are also available in the
Rolls-Royce Motor Cars Phantom, and LOGIC7 is utilized in select models from BMW and Mercedes.
Lexicon is a division of Harman International, Inc. Harman International (www.harman.com) is a leading manufacturer of high quality electronics and speakers for the consumer, professional, and OEM markets. The company’s stock is traded on the New York Stock Exchange under the symbol HAR.
“Lexicon” is a registered trademark of Harman International Industries. U.S. patents and other worldwide patents issued and pending. Other company and product names may be trademarks of the respective companies with which they are associated.
–For more information contact info@neilsonclyne.com or visit the Neilson/Clyne, Inc. editorial website at www.neilsonclyne.com
Lexicon is exhibiting at booth #347 during the CEDIA Expo 2004 in Indianapolis, IN.
Pro-Ject Audio CD Box RS2 Tube Silver CD Player
CD Players
Pro-Ject’s CD Box RS2 Tube doubles down on Red Book CDs with a balanced tube stage—no SACD, no digital inputs, and a $2,300 price...
Backert Labs Optik Phono 1.1 Backert Labs Optik Phono 1.1
Backert Labs’ $11,500 Optik Phono 1.1 targets DS Audio optical cartridges and five-figure turntables—impressive at shows, uncompromising in design, and firmly not for casual...
2026 Samsung Music Studio Series Speakers 2026 Samsung Music Studio Series Speakers
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
HumminGuru EZ Record Washer Package HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
