In-Wall Speakers
LEON Speakers Celebrates 25 Years With The Living Space Theater: CEDIA 2022
Leon Speakers have been a leading brand in the CI space for almost 25 years and they are celebrating with some innovative new products at CEDIA 2022.
Leon Speakers Lifestyle
Leon Speakers is celebrating its 25th Anniversary and will be on hand at the 2022 CEDIA Expo (Booth 18099) demonstrating its current lineup and some very innovative new products.
Leon Speakers is collaborating with Calgary-based, FORT Architecture to bring a design-forward, modern living space to its booth, The Living Space Theater.
One highlight of the space is Leon’s latest collaborative effort with LiquidView. Leon and LiquidView are planning to bring to market a virtual window that provides homes and businesses, with 24-hour high-resolution views that synch to the location and time of day. Other featured products in the Living Space Theater include the Edge TV, Horizon Denza, and Timbre bookshelf speakers
Aside from the Living Space Theater, LEON Speakers will be demonstrating a number of new innovations at CEDIA 2022.
Leon Speakers SoundTile
SoundTiles
Leon Speakers has a relationship with Sonos on their SoundTile product. The SoundTiles are acoustically transparent grills that are designed to hide a system anchored by select Leon Speakers and a Sonos Amp. For CEDIA 2022, Leon Speakers is featuring an artistic collaboration with digital artist Chris Saunders for exclusive pieces of artwork featured in Leon Speaker’s New Ente SoundTile Format. There will be three newly released vertical Ente SoundTiles.
Leon Speakers Tonecase TcBar
TcBar
Leon Speakers announces the latest addition to its popular Tonecase concealment products, the TcBar for soundbars from Sonos, Bluesound, and others. TcBar can be wall-mounted to fit any display size up to 98-inch diagonal, the TcBar is compatible with the Sonos Beam/Beam2, Sonos Arc, Bluesound Pulse 2i, and Bluesound Soundbar Plus
The TcBar complements 45 to 74-inch diagonal screen size TVs while the TcBar-OS is designed for use with 75 to 98-inch diagonal screen size TVs.
Leon Speakers Tonecase TcBar Conceals a Soundbar
Hide your soundbar inside Leon Speakers Tonecase TcBar.
Tip: Custom versions of the TcBar to accommodate other soundbar brands are also available.
The TcBar can be mounted using HzFLUSH brackets. Each unit offers built-to-match width dimensions with furniture-grade finishes, custom paint-matching, and a custom fabric grille. The grill comes in black with the option to change it to a designer grille fabric. The TcBar provides a concealment solution that enhances existing furnishings while housing compatible soundbars.
Leon Speakers Terra LuminSound TRL50 Bollard Outdoor Loudspeakers
LuminSound Bollard Outdoor Speakers
Building off its popular Terra LuminSound TrLS50 outdoor speaker selection, Leon Speakers adds a new, taller model, the Terra LuminSound Bollard.
The Terra LuminSound Bollard speaker features the same handcrafted components and built-in low-voltage lighting as the shorter landscape version but stands taller with its 21-inch aircraft-grade aluminum base.
At an overall height of 32 inches and available with both halo and adjustable pathway lighting, the Terra LuminSound Bollard beautifully defines and enhances any outdoor residential or commercial environment.
Incorporating audio and lighting in one enclosure, the Terra LuminSound Bollard delivers high-fidelity sound from a sleek, customizable package designed and built to withstand even the harshest of climates.
Tip: The Terra LuminSound Bollard is IP67-rated.
This unique speaker is available with commercial-grade LED lighting that can be adjusted upward or downward to illuminate pathways, landscaping, and architectural details, blending discreetly into a variety of landscapes.
Available color finishes include Black, Satin White, Light Sand, Hammertone Silver, Slate Grey, Dark Bronze, and Satin Terracotta.
Hardscape mounting is the preferred installation method for the Bollard model, and like all Terra products, it’s handcrafted in the USA and comes with a limited lifetime warranty.
Terra LuminSound Bollard speakers are sold individually, starting at a suggested retail price of $1,900 without lighting and $2,000 with lighting. They can be purchased directly from Leon Speakers or authorized dealers/installers
Related reading: See all CEDIA 2022 Coverage Here
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
Priced from $2,250 to $7,000 per pair, Monitor Audio's Gold Series 6G loudspeakers include six models for stereo or home theater setups.
Available in two sizes, Climate Series 3G weatherproof speakers are rugged enough for the outdoors and versatile for indoor mounting.
Theory Audio Design has adapted its award-winning in-ceiling and subwoofer drivers for outdoor use.
The new Marantz CINEMA Series A/V Receivers have arrived at CEDIA 2022 and we're already taking the doors off of our media cabinet.
More power, more channels, more streaming, and gaming support highlight Denon's new AV Receivers for the coming year.
In-Wall Speakers
The outdoor CI market is hot and rather wet apparently. The DALI PHANTOM E-60 and E-80 WR in-ceiling speakers will be available from March,...
