Lensbaby Soft Focus Optic
The Lensbaby Soft Focus Optic works with Lensbaby’s Creative Effects SLR camera lenses, the Composer, Muse and Control Freak. Images created with the 50mm focal length Soft Focus Optic feature a soft and diffused appearance. The Soft Focus Optic’s multi-coated optical glass doublet creates a much flatter field of focus than previous Lensbaby optics, making this optic well-suited for a variety of soft focus applications. This new optic does not have the Sweet Spot of sharp focus and dramatic blur outside of that spot created by the Double Glass, Single Glass, and Plastic Optics.
The Soft Focus Optic features Lensbaby’s magnetic disk aperture system. In addition to the standard round aperture disks for f/2 to f/22, the Soft Focus Optic also comes with three special soft focus multi-hole apertures that combine one large opening over the optic’s sharp center with small openings over the optic’s soft edges. This hole pattern creates a sharp underlying image with a soft overlay. Users can stack the soft focus apertures together or with standard Lensbaby apertures to vary the amount and appearance of the softness. In addition, the multi-hole apertures have the ability to create out-of-focus highlights that take on the shape of the aperture holes, further enhancing creativity. When using the Soft Focus Optic, photographers typically point the lens straight ahead to achieve a classic soft focus look.
The Lensbaby Soft Focus Optic is available for $89.95 (MSRP).
Soft Focus Optic Product Specs:
  • Focal Length: 50mm
  • Multi-coated optical glass doublet
  • f/2 optic with aperture disks that range from f/2.8 to f/22
  • Creates images that are overall soft and diffuse
  • Much flatter field of focus than other Lensbaby optics. Suited for variety of soft focus applications such as portrait, landscape, urban, and botanical photography
  • Magnetic disk aperture system
  • Degree of softness can be controlled by changing the special apertures, or stacking them with regular Lensbaby aperture disks
  • With the soft focus multi-hole apertures, bright, out-of-focus points of light take on the hole pattern’s shape. Photographers can control this creative effect by using standard Lensbaby apertures or choosing a low contrast background.
About the Lensbaby Optic Swap System
The Lensbaby Optic Swap System now features six interchangeable optics that can be swapped in and out of Lensbaby’s Creative Effects SLR Camera lenses, the Muse, the Composer, and the Control Freak. Each optic creates a different type of creative image, giving photographers unlimited freedom to achieve their unique artistic vision. The Double Glass, Single Glass, and Plastic Optics have a curved field of focus that allows the photographer to control depth of field in a unique way by creating a Sweet Spot of sharp focus that is surrounded by beautiful blur. The other 3 optic options, Fisheye, Soft Focus, and Pinhole/Zone plate all feature a flat field of focus and create distinctive looks.
XGIMI is marketing its portable projection screen as a complement to its MoGo 3 Pro video projector for outdoor movie watching.
LG G5 OLED TV Lifestyle LG G5 OLED TV Lifestyle
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HOUCHMAND M1 System Lifestyle Image HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
