Camera Lenses
Lensbaby Fisheye Optic
The Lensbaby Fisheye Optic allows photographers to turn their Lensbaby Composer or Muse into a fisheye lens by swapping out the installed optic and dropping the new Fisheye Optic into the lens. This optic’s six element multi-coated optical design features an ultra-wide 12mm focal length capable of capturing a 160 degree fisheye angle of view from infinity all the way down to one-inch from the front of the lens.
The Lensbaby Fisheye Optic features a system of interchangeable aperture disks, with possible aperture settings ranging from f/4 to f/22. To change the aperture, users unscrew the top element of the Fisheye Optic and replace the aperture disk using the included Aperture Tool.
Due to the extremely wide angle field of view, photographers who use a full-frame camera will generally see a black circle around almost the entire image, and smaller APS-sized sensor shooters will see black at the corners of their images. This black edge is typical for standard fisheye lenses. However, the Lensbaby Fisheye Optic features a creative lens flare effect that causes the edge areas that would ordinarily be black to glow with color whenever there are bright light sources in the image. The Fisheye Optic lens flare effect is particularly apparent when shooting with a full frame camera.
The Fisheye Optic is different than previous Lensbaby optics, with a much flatter field of focus than the Double Glass, Single Glass, and Plastic Optics. The images created by the Fisheye Optic are sharp throughout the image at darker apertures. While the Fisheye Optic creates some edge blur at brighter apertures, it does not feature the Sweet Spot of sharp focus and dramatic blur that are trademarks of the Double Glass, Single Glass, and Plastic Optics. Instead of bending the lens, photographers typically will point their Lensbaby straight ahead to achieve a classic fisheye look.
The Lensbaby Fisheye Optic is available for $149.95 (MSRP).
*A special adapter is required to use the Fisheye Optic with the Lensbaby Muse. The Fisheye Optic is not recommended for use with the Lensbaby Control Freak.
Fisheye Optic Product Specs:
  • Focal Length: 12mm
  • Six element multi-coated optical design
  • f/4 optic with aperture disks that range from f/5.6 to f/22
  • Focuses from one inch to infinity
  • Removable disk aperture system
  • To change aperture, unscrew top element of Fisheye Optic and remove with Aperture Tool. The aperture disk sits atop the bottom element
  • Special adapter must be purchased for use with Muse. The Fisheye Optic is not recommended for use with the Control Freak
XGIMI is marketing its portable projection screen as a complement to its MoGo 3 Pro video projector for outdoor movie watching.
LG G5 OLED TV Lifestyle LG G5 OLED TV Lifestyle
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HOUCHMAND M1 System Lifestyle Image HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
