Leica’s Cine Play 1 Might Be the Coolest Portable Projector, But Pricey
At $3,795, does the Leica Cine Play 1 portable projector offer enough in comparison to its rivals from Hisense and Formovie?
Leica Cine Play 1 Lifestyle Projector
In 2023, Leica, in partnership with Hisense entered the UST projector market with its $9,000 Cine 1. That’s a rather expensive ultra short-throw projector, but it did come with either a 100 or 120-inch ALR screen.
For 2024, Leica has borrowed tech and features from the Cine 1 platform and crammed it into a smaller compact lifestyle projector, the Cine Play 1.
Leica Cine Play 1 Front Head-On
Portable Projection
The compact Leica Cine Play 1 combines laser light source technology with Leica premium imaging quality that supports 4K resolution (via pixel shifting) at up to 300-inch screen sizes.
With built-in smart functions, innovative solutions and user-friendly features the Cine 1 play is designed to provide a premium home cinema experience for both indoor and outdoor settings — although getting this to work outside on anything larger than 100 inches might be a real task.
The Leica Cine Play 1 incorporates a triple RGB laser light source that supports up to 25,000 hours of use.
With a white light output of up to 3000 ANSI lumens, the Cine 1 Play can display clear and high-contrast images even in rooms with a lot of ambient light.
For added image display support, the Cine 1 Play supports full HDR (Dolby Vision, HDR10, HDR10+ & HLG) format compatibility; which is rather unusual for a portable projector.
For added image performance, the Cine Play 1 incorporates a Leica Summicron zoom lens, built to standards you would expect from Leica.
To top off image performance, the Cine Play 1 also includes (Leica Image Optimization – LIO) image processing technology. This employs special image optimization algorithms to ensure natural color rendition, finely nuanced color gradation, and an outstanding contrast ratio.
Leica Cine Play 1 Rear View Head On
Audio
Although for the best home theater audio experience, it is best to use an AVR in combination with a surround sound speakers system, that is not always possible or practical, especially with a portable projector.
To support ease of use and ensure maximum portability, the Cine 1 Play, in addition to providing output for an external audio system, also contains a 2 x 10-watt onboard audio system with integrated DTS Virtual:X processing that provides a more immersive listening experience that you might think.
Leics Cine Play 1 Connections
Connectivity
In addition to image and sound, the Leica Cine Play 1 also provides both wireless and physical connectivity.
With built-in smart features, users can access and connect right out of the box, provided the Cine Play 1 is connected to the internet via Wi-Fi or Ethernet. The Cine Play 1 also supports Apple Airplay and Bluetooth. Bluetooth allows streaming from smartphones, laptops, tablets, or other compatible external drives.
The VIDAA streaming platform provides access to streaming apps, including Netflix. Smart home integration and voice control add further convenience.
Physical input connectivity includes 2 HDMI and 2 USB ports. One HDMI port supports eARC for easy connection to compatible AVRs or soundbars.
Leica Cine Play 1 Rear View Angle
Flexibility
The Leica Cine Play 1 is very flexible. By keeping the weight to only 14 pounds, it is easy to carry from place to place and can be set up almost anywhere without any need for permanent installation.
Integrated automatic alignment functions enable image and focus settings with no need for manual fine-tuning.
Leica Cine Play 1 Optional Floor Stand
Optional floor stand costs $495 extra.
The Leica Cine Play 1 combines innovative technologies with minimalist design that was inspired by the Bauhaus School
To complement the Cine Play 1, Leica offers an attractive and practical floor stand. The floor stand is designed not only to support the technical performance of the projector but also to display the attractiveness of the projector.
Leica Cine Play 1 Optional Floor Stand Connections
With an integrated, safe, and secure pin contact system in the Floor Stand, the projector requires no visible power cable. Power is supplied through the baseplate of the Floor Stand. The floor stand also allows users to position the Leica Cine Play 1 at an ideal viewing angle.
Comparison
Here is a comparison of the Cine Play 1 with two other compact lifestyle projectors.
Leica Cine Play 1, Hisnse C2 Ultra, Formovie x5
Cine Play 1Hisense C2 UltraFormovie x5
Price$3,795$2,999$1,499
Projection Size65 – 300”65-300″60-1,000″
Imaging ChipDLP/0.47” 4k XPRDLP/0.47” 4k XPRDLP/0.47” 4k XPR
Image Resolution3840 x 2160px (4K) via pixel shifting3840 x 2160px (4K) via pixel shifting3840 x 2160px (4K) via pixel shifting
Gaming ModeYes, Latency < 12 ms 1080px@120HzYes, Latency < 12 ms 1080px@120Hz4K/60Hz: 42.5ms
Lumen OutputUp to 3000 Lumens (Ultra Mode)3000 ANSI Lumens2450 CVIA Lumens
Dynamic ContrastApprox. 2,000,000:12,000,000:1(dynamic)Not Indicated
Contrast Ratio1500:1Not Indicated1200:1 (Full On/Off)
BT 2020 Support> 100%110% Not Indicated
HDR SupportDolby Vision/ HDR10+/HLGDolby Vision/HDR10/HLGHDR10/HLG
IMAX EnhancedYes
3D SupportYesYes
Throw Ratio(0.9-1.5):1(0.9-1.5):11.27:1
Leica Image Optimization (LIO)Yes
Light SourceDirect Triple RBG-LaserDirect Triple RBG-LaserALPD 3.0 Laser
MEMC (Motion Estimation/Motion Compensation)YesYesYes
HDMI2 x HDMI 2.1
(1x eARC Support)
1x HDMI 2.0
1x HDMI 2.1 (ALLM)
HDMI Arc, CEC:
2 x HDMI 2.1
Digital Connections1 x S/PDIF
1 x Optical (Toslink)
1 x Digital Audio Output:
1 x Optical
1 x S/PDIF
USB2 x USB 3.01 x USB 3.0
1 x USB 2.0
1 USB
USB RecordingYesNot IndicatedNot Indicated
Ethernet RJ45YesYesYes
Earphone/Audio Output 1 x 3.5mm1 x 3.5mm1 x 3.5mm
Audio Output Power2 x 10 Watt2 x 10 Watt2 x 12 Watt +
1 x 6 Watt
Number of Channels 22 (JBL)3.1 (Denon)
DTS Virtual:XYesNot IndicatedNot Indicated
DTS:XNot IndicatedYesNot Indicated
Dolby AudioYesNot IndicatedYes
Dolby AtmosYesNot Indicated
WiFi6 (IEEE 802.11 a/b/g/n/ac/ax)6 (IEEE 802.11 a/b/g/n/ac/ax)6 (IEEE 802.11 a/b/g/n/ac/ax)
Bluetooth YesYesYes
Screen MirroringYesYesNot Indicated
Works with AirPlayYesYesNot Indicated
Operating SystemVIDAA OSVIDAA OSComes with Fire TV Stick 4K MAX
Streaming Direct Buttons on RemoteYes, for Netflix, Prime, Disney, YouTubeYes, for Netflix, Prime, Disney, YouTubeNot Indicated
Voice AssistantYes – AlexaYes – AlexaNot Indicated
Web BrowserYesNot IndicatedNot Indicated
Remote ControlBluetooth / IR in Aluminum Housing with MicrophoneVoice remote with backlightYes
Voice CommandYesYesNot Indicated
File FormatsAV-Container: AVI / MP4 / MKV/ TS / FLV
Video: AVI / WMV / MP4 / MOV / MKV / MPG / MPEG / FLV / WebM
Audio: WMA / WAV / FLAC / MP3
Image: JPEG / BMP / PNG / GIF
Power ConsumptionOn 180W / Standby 0.5WOn 180W / Standby 0.5WNot Indicated
Voltage100V – 240V100V – 240V100V – 240V
Dimension10.3 x 9.5 x 9.0 inches9.7 x 7.1 x 8.5 inches8.54 x 8.27 x 6.57 inches
Weight14.7 lbs13.9 lbs8.77 lbs
Included AccessoriesRemote control
2 AAA batteries
Power cable
Power supply unit
Accessory bag
Operating instructions & Warranty.
Quick Start Guide / Manual:
QSG inbox
Manual online
Power Cable: Yes
Cleaning Kit: Yes
Not provided
Leica Cine Play 1 Portable Projector Angle
The Bottom Line
We were impressed with Leica’s first entry into the projector space, the Cine 1. With exceptional build quality, responsive interface, and let’s not forget, the inclusion of Leica lens and optical technologies, it had something to offer in the projector space.
For 2024, Leica appears to have taken the next step into the projector space with Cine Play 1. What makes this model different is that instead of being designed for use in stationary higher-end home theater setups, Leica has decided to shake up the lifestyle projector category.
The good thing is that they have managed to cram of lot of what’s great about Cine 1 into a smaller package. There is no issue with light output and practical features, but once again, the Cine Play 1 is on the expensive side.
The main issue will be pricing — and especially because it was developed in partnership with Hisense that already offers the C2 Ultra ($2,499 at ProjectorScreen) for less.
Does the Leica “secret sauce” make it worth the difference in price?
Price & Availability
The Leica Cine Play 1 is available in selected Leica Stores and from authorized dealers for $3,795. The Leica Floor Stand costs $495.
Related Reading
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
HDTV 4K & 8K TV
At 85 or 98-inches, the top-of-the-line 2025 TCL X11K 4K TVs boast 6,500 nits, 14,000 dimming zones and HALO Control Technology.
Ask an Expert
HLG is one of several HDR formats in use. Find out what makes if different and what this means for TV viewing
Ask an Expert
Dolby Vision gets all the HDR hype, but HDR10+ also has a lot to offer. Let’s check out more about this dynamic HDR format.
HDTV 4K & 8K TV
Bigger screens, elevated processing, better sound, wireless connectivity, and WebOS enhancements highlight LG's 2025 QNED evo TVs.
With a 5,000-lumen light output the Optoma UHZ68LV home theater projector can work with screens up to 300-inches.
Sister Company to UST Projector Maker AWOL, Valerion has a line of standard throw projectors that might be just right for you
HDTV 4K & 8K TV
TCL is putting Samsung, LG, and Hisense on notice with its featured packed TCL QM6K Series QD-MiniLED TVs (50 to 98 inches).
HDTV 4K & 8K TV
Amazon introduces top-of-the-line Omni Series Mini-LED QLED 4K TVs in sizes from 55 to 85-inches at affordable price points.
