Lansche Audio No. 7 Loudspeakers
Lansche Audio announced the Model No. 7 Three-Way Passive Floor Standing Loudspeaker System featuring their Corona Plasma Tweeter.
The No. 7 Speaker unites acoustic fidelity, uncompromising quality and technical innovation with an extraordinary flexibility to achieve the best possible audio experience regardless of room characteristics. It delivers musical performances that sound as direct and natural as when they were originally performed, with no restrictions in dynamic range, frequency spectrum or the pleasure of feeling transported to a live musical experience.
The new No. 7 Speaker includes a new, improved version of the Corona Tweeter, a new aluminum front baffle, integrated adjustable footers for perfect leveling, and bi-wiring terminals. All are housed in a pair of majestic, masterfully crafted cabinets, 69 inches high by 17 inches wide by 24 inches deep, that are as dramatic in appearance as they are dynamic in sound.
The speakers reproduce midrange frequencies using two 4-inch cone drivers from Audio Technologies. They also use four 8.7-inch long-throw drivers for bass, the Corona Plasma Tweeter for higher frequencies, and two passive bass reflex ports in the rear. The 4-inch drivers’ low mass integrates crucial midrange frequencies with the plasma tweeter, while the 8.7-inch woofers consist of coated fabric cones of glass fiber and polyester.
Lansche Audio Corona Plasma Tweeter
A hallmark of Lansche technology, the Corona Plasma Tweeter, employs an 8mm-long electric arc to directly activate the surrounding air as a sound transmission medium. It comes closer than any other tweeter to the ideal of a point-shaped sound source with zero mass. The tweeter’s arc of resonance-free, voltage-modulated air helps it avoid the limitations of conventional tweeters to achieve outstanding impulse, phase and amplitude response, and an exact, three-dimensional sound. As a result, the No. 7 delivers faithful, coherent musical reproduction with incredible precision, speed and economy.
The rear of each speaker includes a connection panel with input terminals that accept banana plugs and spades for midrange and high frequencies, six terminals for making treble and bass adjustments, an IEC AC power jack, and a fuse. Two jumpers and two cable bridges per speaker are included with each pair of No. 7 Speakers. Bass reflex ports and an on/off switch rest in the middle of each back panel, and pairs of cooling vents are on the sides.
The particular acoustics of a room influence the sound of every speaker. A room’s design, the positioning of the speakers, the influences of furniture, curtains, and other objects can negatively affect the quality of a listening experience. One of the great virtues of the No. 7 is that it can be adjusted to the acoustic properties positioning restrictions of any room in which it is employed. For example, a sparsely furnished room without sound-absorbing elements such as carpets tends to produce an exaggerated treble response. A room with many sound-absorbing elements will make the treble seem duller. The two jumpers on the speakers’ rear terminal panel are for adjusting both the treble and bass responses. To change one, the user can simply pull out a jumper and reinsert it into a more appropriate of the available six terminals.
Price and Availability
The Lansche No. 7 Loudspeaker is available now from Aaudio Imports at suggested prices of $100,000/pair in a Satin Veneer finish, and $108,000/pair in a High Gloss Veneer or Piano Black Lacquer finish.
Specifications
Description: 3-way passive loudspeaker vented-box system
Tweeter chassis: 1 x 8mm (0.3″) Corona Plasma
Midrange chassis: 2 x 15.5 cm (4″)
Bass chassis: 4 x 22cm (8.7″) composite glass fibre/ polyester fabric cone, coated
Crossover frequencies: 200Hz / 2.5kHz
Impedance: 6.8Ω nominal, 4.9Ω
Sensitvity: minimum 92dB/1W/1m
Maximum level: 114dB/1m
Frequency response: 25Hz – 150kHz ±3dB
Input terminals: 2 sets: 1 x bass, 1 x mid+high,
connection for bi-wiring or bi-amping
Internal wiring: Silver plated OFC
Dimensions (HxWxD ): 175 x 32 (43) x 61 cm
69 x 12.5 (17) x 24 inches
Weight: 130 kg (286 lbs)
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
