LaCie XtremKey USB Flash Drive
LaCie announced the LaCie XtremKey — offering industrial-strength protection for your data. With capacities up to 64GB and an impenetrable shell, the XtremKey is a truly rugged USB key that stands up to the elements.
LaCie, originator of the flat, award-winning key-shaped USB flash drives, shields the XtremKey's premium flash memory modules inside a 2mm metal pipe casing. Sealed with wear-resistant screw threads and a rubber O-ring, it is watertight up to 100 meters. The LaCie XtremKey is also resistant to 5-meter drops, fierce heat and bitter cold — it holds up in any environment, no matter where you take it (+200°C / -50°).
XtremKey is constructed with zamac, a metal alloy composed of zinc, aluminum, magnesium and copper that's so strong, it can withstand the pressure of a 10-ton truck. Less than three inches tall, this flash memory drive puts strength, security and storage right on your keyring.
Equipped with the Hi-Speed USB 2.0 interface, XtremKey offers instant compatibility, outstanding transfer speeds and cross-platform convenience to all PC and Mac® users. With writing speeds up to 30 MB/s and reading up to 40 MB/s, you don't have to sacrifice performance for protection.
Designed by Constance Guisset exclusively for LaCie, XtremKey works relentlessly to keep your data protected, all while being portable, powerful and perfectly suited for your life's adventures. The key, when placed on a desktop, even shows some playful personality with a perfectly balanced wobble effect.
Availability
The LaCie XtremKey comes in capacities from 8GB to 64GB and will be available in August for $49.99.
“The XtremKey offers extreme durability and capacity in a convenient, well-protected and fun form factor. Despite the robust, industrial-strength protection we've added, it's still a LaCie key that brings ease-of-use and reliability to customers looking to keep their data secure while on the go.”
— Alexis Kobassian, Product Manager, LaCie
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
