LaCie XtremKey USB 3.0 Flash Drive
Flash Drive
Thumb DriveLaCie announces XtremKey USB 3.0 thumb drive offering rugged storage protection with fast transfer speeds up to 230MB/s. The flash drive is IP-68 Level 8 certified, making it watertight up to 200 meters (656 feet). Its memory modules are shielded inside a 2mm casing and sealed with wear-resistant screw threads and a hermetic, rubber O-ring.
The LaCie XtremKey features a protective cap made of thick ZAMAC metal alloy. Its strength can withstand severe shock, dizzying drops, and the relentless pressure of a 10-ton vehicle. It also survives bone chilling temperatures down to -30°C, and scorching heat up to 200°C.
LaCie’s Private/Public software comes standard on the key and provides impenetrable data protection. The AES 256-bit software encryption protects sensitive documents with password authentication, so even if the key is lost or stolen the files remain inaccessible.
Price and Availability
The LaCie XtremKey USB 3.0 is available now in a 32GB capacity for $84.99. A 64GB version will be available January 2013.
[youtube id=”1vLuUCxm52c” width=”610″ height=”373″]
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
