Network Attached Storage
LaCie Wireless Space NAS Storage
LaCie introduced its first network-attached storage solution to feature Wi-Fi. The LaCie Wireless Space can operate as a file or media server for multiple Mac® and PC users, from anywhere in the home — making it the most compatible and multifunctional network hard drive on the market.
Leveraging Wi-Fi technology, the Wireless Space can connect to your existing Wi-Fi network, allowing you to access files wirelessly throughout the home, and can serve as a central storage solution for all your backups. If you wish to increase your Wi-Fi performance, the Wireless Space can also act as a b/g/n access point, and even serve as a full-featured router.
LaCie Wireless Space - Back
For users with a large media library, the Wireless Space can also act as a media server. It's compatible with UPnP/DLNA and iTunes, and you can stream music, movies and photos from a central location and play them on any device.
Additionally, the Wireless Space is Time Machine compatible, so Mac users can use it as a target for their automatic backups and be confident that all important files and media are safely protected. LaCie also delivers Genie Timeline Software for scheduled backups on the PC.
Designed exclusively for LaCie, Neil Poulton's sleek, polished black design is engineered for natural heat dissipation and near-silent operation. The sophisticated design and Wi-Fi functionality of the Wireless Space makes it a perfect addition to any home network.
“There are a variety of network devices you need to buy to have a full solution to connect your computers, share media and back up your files. LaCie is thrilled to bring Wi-Fi connectivity to the Wireless Space and deliver a truly all-in-one solution for the varying different network needs of any home.”
— Julien Ott, Product Manager for Network Attached Storage, LaCie.
Availability
The LaCie Wireless Space is currently available in Europe in 1TB and 2TB capacities. Both models will be available in the US this October through the LaCie Online Store, LaCie Corner, and LaCie Reseller+ for $229.99 (1TB) or $349.99 (2TB).
LaCie Wireless Space - Packaging
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
