External HDD
LaCie Starck Mobile USB 3.0 Hard Drive
LaCie announced the LaCie Starck Mobile USB 3.0 portable 500GB hard drive designed by Philippe Starck. It is encased in 2mm of sturdy aluminum which provides resilience from blunders, improved heat dissipation, and is fully recyclable. Utilizing USB 3.0 technology the hard drive offers speeds up to 10 times faster than USB 2.0
Ensuring connectivity is never an issue, the LaCie Starck Mobile USB 3.0 is backward compatible with USB 2.0 — simply connect it into any PC or Mac for a seamless plug-and-play experience.
The LaCie Starck Mobile USB 3.0 comes with LaCie Setup Assistant software to easily install your drive on PC and Mac. It also includes LaCie Backup Assistant, which helps make automatic backup a snap. In addition, you get 10GB of Wuala Online Storage included for one year to securely store, share and sync your data online.
Price and Availability
The LaCie Starck Mobile USB 3.0 will be available in a 500GB capacity for $109.99.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
