External HDD
LaCie Rikiki Go 1TB Portable Hard Drive
LaCie introduced the smallest 1TB hard drive in metal — the LaCie Rikiki Go. Measuring a mere 155cm3, its high capacity and portability make it a perfect companion for keeping your digital world close at hand.
Outfitted with an embedded USB 2.0 cable, Rikiki Go connects instantly with your PC or Mac®. Simply remove the cable and plug it in — you're ready to store and share your favorite media with high–speed performance. Additionally, the Rikiki Go is encased in sturdy aluminum, giving it a resilient form factor that protects your media from everyday blunders.
LaCie Rikiki Go Portable Hard Drive with Laptop
Rikiki Go comes with a simplified software suite for quick setup and easy–to–use backup management, enabling complete configuration in just a few clicks. It also offers USB Boost software for enhancing speeds up to 33% (Windows® only). Completing the software offering, the Rikiki Go comes with an additional 10GB of Wuala Secure Online Storage.
Three models of the popular LaCie Rugged mobile hard drive also offer 1TB capacity. No matter what your needs are — be it USB 3.0 speeds, FireWire connectivity or biometric encryption — LaCie users can benefit from a 1TB solution. The LaCie Rugged triple interface and LaCie Rugged Safe are the world's only 1TB mobile hard drives with FireWire.
Availability
The LaCie Rikiki Go is available in 500GB and 1TB capacities through the LaCie Online Store, LaCie Corner, and LaCie Reseller+ starting at $89.99.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
