External HDD
LaCie d2 and 2big USB 3.0 Hard Drives
LaCie announced the two new SuperSpeed USB 3.0 hard drives, the LaCie d2 3TB and LaCie 2big 6TB. LaCie's 2big USB 3.0 achieves a dramatic 20% speed boost by reaching 306MB/s — the fastest performance of any 2-bay RAID solution to-date. The d2 USB 3.0 also demonstrates a significant speed increase of 156MB/s with the inclusion of a 3TB hard drive.
LaCie d2
The LaCie d2 USB 3.0 features 7200 rpm drives, and reaches up to 156MB/s, making it ideal for creative professionals looking for high transfer speeds. The d2 USB 3.0 is designed to integrate into any professional work environment. It comes standard with advanced backup software, which helps to make it extremely reliable. With the performance of USB 3.0, you can transfer large files and perform backups faster than ever before. Its unique fanless aluminum heat sink design prevents overheating by providing efficient and still unmatched ultra-quiet and safe heat dissipation. The LaCie d2 USB 3.0 is versatile and can stand upright, be stacked horizontally with other drives, or rackmounted to save desktop space. In addition, it helps you reduce power consumption by switching to its eco mode after 30 minutes of inactivity. For better energy efficiency, it will also automatically shut down when unplugged from the computer. On top of that, it's recyclable.
LaCie 2Big 6TB USB 3.0 Hard Drive
LaCie 2big
The 2big USB 3.0 is the first RAID storage solution to feature the new SuperSpeed USB 3.0 interface, and supports multiple uncompressed HD streams. With three RAID modes for flexibility, you can choose “Fast” (RAID 0) to get speeds of up to 306MB/s, “Safe” (RAID 1) for full data protection, or JBOD for non-stop data access. With its 7200 rpm drives and compatibility with USB 2.0, the LaCie 2big USB 3.0 is the most complete USB 3.0 storage device. The unique fanless aluminum heat sink design is sturdy and features 60% more surface area, providing the most efficient heat dissipation. This keeps it ultra-quiet, and protects the hard disk. The LaCie 2big USB 3.0 helps you to reduce power consumption by letting you program when it switches to idle mode. You can schedule a deep sleep on/off mode according to your needs, and the 2big USB 3.0 can be switched back to operating mode from the client side.
Availability
The LaCie 2big USB 3.0 6TB and LaCie d2 USB 3.0 3TB will be available, worldwide, at the beginning of November.
Hisense S5 DecoTV Front Lifestyle
Hisense’s S5 DécoTV proves not every TV needs to be enormous, blindingly bright, or pretending to be a gaming rig—just a smart, good-looking 32-inch...
LG Micro RGB Evo TV 2026 LG Micro RGB Evo TV 2026
LG previews its Micro RGB evo MRGB95B 4K TV ahead of CES 2026, marking a rare LCD shift with bold color claims, AI processing,...
2026 Samsung R95H 4K TV Angle 2026 Samsung R95H 4K TV Angle
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
