LaCie announced the 10-bit P-IPS LCD panel, LaCie 324i professional display. An ideal monitor for prepress, illustration, web design, and photographic workflows, the LaCie 324i delivers uniform and accurate colors thanks to its wide gamuts and backlight stabilization.
Lifelike Clarity
The LaCie 324i P-IPS panel offers a realistic presentation without discoloration or inconvenient pattern distortions. Distinguished by its impressive gamut spectrum, the LaCie 324i color is rated at 102% NTSC and 98% Adobe RGB. With wide gamuts that are not disturbed by irregular patterns, digital artists can rely on true colors that maintain the integrity of their work.
Enhanced Workflow
Designed for versatility in any office or studio, the LaCie 324i 178° viewing angle provides the same visual experience and quality from numerous axes, without distorting the picture or losing color. Further, its anti–glare panel guarantees that you will not have to worry about unwanted reflections often found on glossy panels.
With 24 inches of usable workspace and a native 1920×1200 resolution, users can enjoy two projects at once, with room for toolbars and palettes. If Landscape is not the desired display mode, simply pivot the LaCie 324i 90° to Portrait mode. The multifunction stand glides effortlessly when raising, lowering, swiveling, tilting, or pivoting the display.
Additionally, the 324i comes with a 3–year Gold Protection Plan that includes a robust 3–year advance care warranty. If you experience a problem, LaCie will ship a replacement monitor immediately — so you never have to worry about downtime.
Absolute Accuracy
In addition to its 1000:1 contrast ratio and backlight stabilization — for the brightest whites and darkest blacks — the LaCie 324i can be further enhanced with the optional LaCie blue eye calibration tool. The included software also provides prepress professionals with the option to enhance soft proofing accuracy using test and report features approved by UGRA (the Swiss Center of Competence for Media and Printing Technology).
Enhanced Connectivity
The LaCie 324i has four display and video inputs, making it compatible with most computers and video devices. Use DisplayPort or DVI–D for connecting the monitor to a computer and HDMI or component for video sources. The 324i also has three USB 2.0 ports for a convenient USB hub to your computer. All cables are neatly arranged in the 324i's handy cable manager.
Availability
The LaCie 324i P–IPS LCD Monitor is available from the LaCie Store Online or through LaCie Color Partner and LaCie Reseller+, starting at the suggested retail price of $1,249.00.
