Krell S-550i Integrated Amplifier
Krell just released the S-550i Integrated Amplifier, which upgrades the performance of their S-300i integrated amp. The new S-550i delivers 275-watts of output, with balanced and single-ended inputs, iPod dock, and Theater Throughput mode to simplify integration into home theater systems. For custom integration applications, 12 Volt triggers, RS-232 connectivity and rack mount ears are included. Operational parameters can be customized via the menu system that is accessible from the front panel or the included brushed Aluminum remote control.
Preamplifier Highlights
The preamplifier section features circuit concepts from Krell’s flagship Phantom preamp. Krell Current Mode provides unequaled bandwidth for the most revealing playback of today’s high-resolution music sources. Direct coupled circuitry eliminates impact-robbing capacitors from the signal path and an elegant, custom-machined level control adjusts volume. Discrete circuitry, in a balanced topology, is afforded its own power supply regulation. All signal gain is realized using surface mount technology featuring proprietary current mirrors with nearly 500 times the open loop linearity of other designs. Negative feedback is not used anywhere in the preamplifier, nor is it necessary. Open-loop distortion is typically less than 0.003%. The volume control is realized with a balanced resistor ladder – bandwidth and transient response of the preamp circuitry are virtually unaffected by the volume setting.
Krell S-550i Integrated Amplifier - back
Power Amplifier Highlights
The S-550i packs a massive 1,750 watt transformer and 68,000?F of capacitance into an elegant 5″ high chassis. This power supply feeds classic Krell circuitry throughout the topology using only discrete circuitry. As with all Krell amplifiers, the S-550i design is an ideal voltage source. That is, the S-550i doubles its power output when a speaker’s impedance is halved. For the S-550i, the results are 275 watts into 8 Ohms and 550 watts into 4 ohms both channels driven. This capability is essential for realistic reproduction of a recording’s dynamic content. Most amplifiers can’t deliver this power doubling, leaving music sounding compressed and lifeless.
Price and Availability
The Krell S-550i Integrated Amplifier is available now for $5,000 in silver and black finishes.
Specifications
Inputs
1 pr. balanced via XLR connectors
3 pr. single-ended via RCA connectors
1 dedicated iPod input via 30-pin connector
Outputs
1 pr. preamp outputs via RCA connectors
1 pr. speaker outputs via gold-plated binding posts
Control inputs
1 RS-232 input via 9-pin D-subminiature connector
1 remote IR detector input via 3-conductor 3.5 mm connector
1 12 VDC trigger input via 2-conductor 3.5 mm connector
Control output
1 programmable 12 VDC trigger output (30 mA maximum current) via 2-conductor 3.5 mm connector
Input impedance
Balanced: 95 kΩ
Single-ended: 47.5 kΩ
Frequency response
20 Hz to 20 kHz +0, -0.08 dB
Signal-to-noise ratio
>89 dB, wideband, unweighted, at maximum gain, referred to full power output
>96 dB, “A”-weighted
Gain
32.0 dB
Input sensitivity
Single-ended or balanced: 1.18 V RMS
Total harmonic distortion
<0.025% at 1 kHz, at 275 W, 8 Ω load
<0.20% at 20 kHz, at 275 W, 8 Ω load
Output power
275 W RMS per channel at 8 Ω
550 W RMS per channel at 4 Ω
Output voltage
133 V peak to peak
47 V RMS
Output current
20 A peak
Slew rate
80 V/μs
Output impedance
Damping factor
>110 at 20 Hz, referred to 8 Ω
>75, 20 Hz to 20 kHz, referred to 8 Ω
Power consumption
Standby: 1 W
High-current standby: 40 W
Idle: 90 W
Maximum: 1800 W
Heat output
Standby: 3.4 BTU/hr
High-current standby: 140 BTU/hr
Idle: 310 BTU/hr
Maximum: 2400 BTU/hr
Specifications for preamp only:
Gain
6.3 dB (single-ended)
Volume control
Current-mode, 12-bit, discrete R-2R ladder
Input overload
Balanced: 12 V RMS
Single-ended: 6 V RMS
Output overload
8 V RMS (single-ended)
Frequency response
20 Hz to 20 kHz +0, -0.05 dB
<0.009%, 20 Hz to 20 kHz, at 2 V RMS
>87 dB, wideband, unweighted, at maximum gain, referred to 2 V RMS
>94 dB, “A”-weighted
Dimensions
17.26 in W x 5.84 in H x 17.70 in D
438 mm W x 148 mm H x 450 mm D
Weight
Unit only: 64 lb [29.0 kg]
As shipped: 76 lb [34.4 kg]
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
Brooklyn-based Ohm Acoustics have been manufacturing loudspeakers for almost 48 years. A deep dive by the Budget Audiophiler.
Loudspeakers
Orange, CT – September 2005 — Krell Industries is meeting the stylistic desires of its demanding clientele by releasing the popular Resolution Series loudspeakers...
The new Evolution lineup of products builds on the design and manufacturing excellence realized with the Evolution One and Two. Orange, CT — February...
Orange, CT — October 2006 — Krell Industries proudly announces shipping of the Evolution 403 and 900 amplifiers from their recently introduced Evolution series....
KRELL APPOINTS NEW NORTHWEST REGION ACCOUNT MANAGER Retail industry vet hired to grow new and existing accounts on the west coast. Orange, CT —...
CD Players
Krell announced its new Cipher SACD/CD player combining elegant industrial design with advanced the state of the art SACD/CD reproduction. Housed in a classic...
Krell just released a state-of-the-art 7.1-channel A/V processor called Foundation, which decodes the latest lossless audio formats, offers extensive digital switching, 3DTV pass-through, and...
Digital Music Systems
Krell announced a high-resolution digital audio streaming player for audiophiles who demand up to 192kHz/24-bit sonic purity. The Wi-Fi-equipped Connect Stream Player is available...
