Krell iBias Class A Amplifiers
Krell Amplifier
Krell announced the most revolutionary design change in its 33-year history: iBias, a patent-pending new technology that uses the Class A circuitry preferred by audiophiles yet consumes far less energy than a traditional Class A amplifier does.
The new line includes seven models, each one built into a 3U-high (5.25 in/134mm) chassis with removable rack-mount ears. The model numbers of the amplifiers indicate their power in watts RMS per channel into an 8-ohm load. The line includes two monoblocks, the Solo 550 and Solo 375; two stereo amps, the Duo 175 and Duo 275; the three-channel Trio 275; the five-channel Chorus 5 and the seven-channel Chorus 7.
Because iBias technology eliminates crossover distortion, it allows the low-level details, subtleties and spatiality of music to come through exactly as they do in a traditional Class A amplifier. Yet iBias also allows these new amplifiers to produce the nearly limitless dynamics that is the hallmark of Krell’s sound.
“Class A amplifiers have always been the preferred choice of audiophiles, and they’ve been a hallmark of Krell engineering for decades,” Bill McKiegan, president of Krell Industries, said. “But concerns about energy consumption have reduced some of the enthusiasm for Class A. We are now building in our Connecticut factory a new type of amplifier with musicality that surpasses that of Class A and the energy-efficiency of newer Class G and H designs. Our iBias designs deliver all of this in a surprisingly compact package – and it also incorporates Internet-based technology that will amaze both audiophiles and systems integrators.”
How iBias Works
Class A amplifiers eliminate crossover distortion (the distortion that occurs when the audio signal shifts from positive to negative polarity) by operating the output transistors at full power all the time so they never shut off. Any energy not required to drive the speaker is dissipated through the amplifier’s heat sinks.
In an iBias amplifier, a circuit continuously measures current flow through the amplifier’s output transistors, and instantly adjusts the power (or bias) going to the transistors to suit the demands. The output transistors never shut off, yet very little power is wasted as heat. Not only does the amplifier consume less power, it runs cooler and can be built into a more compact chassis.
“The iBias amplifier is like a high-efficiency 12-cylinder automotive engine in which some of the cylinders shut down when you don’t need all that power,” McKiegan explained. “Just as that engine can run efficiently yet deliver 600 horsepower in an instant, the iBias amplifier can run efficiently yet in a matter or microseconds gives you hundreds of watts of full Class A bias for musical peaks.”
Installation-Friendly Features
iBias amplifiers also incorporate features that make them much more practical for custom installation than most high-end amplifiers are. As mentioned previously, the amplifiers are built into relatively small, rack-mountable chassis, making them practical for use in places where a traditional Class A amplifier would likely be too large. Proper cooling is assured through the use of thermostatically controlled fans chosen specifically for their ultra-quiet operation.
In order to assure reliable, consistent operation for years, Krell has added Ethernet capability to all iBias amplifiers. Through the Ethernet connection, each amplifier can be accessed on its own web page through any device that can run a Web browser, such as a smartphone, tablet or computer. Using this interface, the dealer or customer can view heat sink temperature, fan speed, and other information, and also receive alerts for such conditions as overheating, fan failure and shorting of the output terminals.
Like the newest Krell products including the Foundation A/V Preamp Processor and the Connect Stream Player, the iBias amplifiers feature stunning industrial design with precision-machined metalwork and distinctive lines. The sleek look is enhanced by the complete absence of visible screws or fasteners on the top, front and sides.
“The iBias amplifiers have the rich, lush, elegant midrange and top end that Class A is known for, with the superb bass and dynamics that has defined the Krell sound,” McKiegan said. “iBias brings audiophile sound to integrators and the custom market, with the convenience features and energy-efficiency they need today. And while audiophiles will find them to be among the most musical amplifiers ever made, they’ll also find that their compact size and cool operation make them much more practical to own than most high-end amplifiers.”
Pricing and Availability
All Krell iBias power amplifiers have begun shipping or will ship later this month. Here are the prices:
  • Duo 175 – 175 wpc stereo – $7,500
  • Duo 300 – 300 wpc stereo – $9,500
  • Chorus 5200 – 200 wpc 5-channel – $7,500
  • Chorus 7200 – 200 wpc 7-channel – $9,500
  • Solo 375 – 375 watt monoblock – $8,750
  • Solo 575 – 575 watt monoblock – $11,250
  • Trio 300 – 300 wpc 3-channel – $11,500
Q Acoustics Q SUB Subwoofer Series in Satin Black
All under $1200, three new Q SUB subwoofers get the most out of Q Acoustics stereo and surround sound speaker systems.
TCL QM7K QD-MiniLED TV Lifestyle 2025 TCL QM7K QD-MiniLED TV Lifestyle 2025
HDTV 4K & 8K TV
With sizes up to 115 inches and fairly affordable pricing, TCL's QM7K MiniLED TV will be one to watch in 2025.
Fluance Wireless Floorstanding Speakers Lifestyle Fluance Wireless Floorstanding Speakers Lifestyle
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
Arendal 1961 Loudspeakers Arendal 1961 Loudspeakers
The Arendal Sound 1961 loudspeaker line is not ready to be retired. Check out all 6 speakers and 2 subwoofers priced under $2000/pair.
Placing record on Turntable PP-1 from above Placing record on Turntable PP-1 from above
Are you one of those people who hates having to install a phono cartridge? The Waiting for Ideas PP-1 might be exactly what you're...
EE1 Plus with Cable EE1 Plus with Cable
Audio Cables
At £600, the EE1 Plus is designed to reduce interference and noise on wired networks, but do you really need it?
Ultimate Man Cave Gift Guide 2025
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
Brooklyn-based Ohm Acoustics have been manufacturing loudspeakers for almost 48 years. A deep dive by the Budget Audiophiler.
Loudspeakers
Orange, CT – September 2005 — Krell Industries is meeting the stylistic desires of its demanding clientele by releasing the popular Resolution Series loudspeakers...
The new Evolution lineup of products builds on the design and manufacturing excellence realized with the Evolution One and Two. Orange, CT — February...
Orange, CT — October 2006 — Krell Industries proudly announces shipping of the Evolution 403 and 900 amplifiers from their recently introduced Evolution series....
KRELL APPOINTS NEW NORTHWEST REGION ACCOUNT MANAGER Retail industry vet hired to grow new and existing accounts on the west coast. Orange, CT —...
CD Players
Krell announced its new Cipher SACD/CD player combining elegant industrial design with advanced the state of the art SACD/CD reproduction. Housed in a classic...
Krell just released the S-550i Integrated Amplifier, which upgrades the performance of their S-300i integrated amp. The new S-550i delivers 275-watts of output, with...
Krell just released a state-of-the-art 7.1-channel A/V processor called Foundation, which decodes the latest lossless audio formats, offers extensive digital switching, 3DTV pass-through, and...
