CD Players
Krell Cipher SACD/CD Player
Krell announced its new Cipher SACD/CD player combining elegant industrial design with advanced the state of the art SACD/CD reproduction. Housed in a classic Krell machined aluminium cabinet and available in silver or black, the beautiful exterior only hints at the sophisticated disc playback technology within its walls.
Featuring an advanced disc drive and coupled to the latest Krell digital and analogue output circuitry, the Krell Cipher delivers the ultimate performance from today's highest resolution source material. Every performance enhancement is incorporated to retrieve the most accurate signal from SACD and CD music titles. Isolated mechanically from the underlying chassis, the drive mechanism utilizes composite mounts to minimize vibration-induced errors. Special sound-dampening material is strategically placed inside the unit to minimize mechanical resonances even further.
Krell customized disc drive firmware enhances reading accuracy, drive mechanics and operational parameters. As an ultimate final step, the separate SACD and CD laser heads are individually calibrated by hand for the precise output levels required for reference quality SACD and CD playback.
All signals are fed into a custom designed Krell anti-jitter module that reduces jitter to a virtually immeasurable level. From there, signals are fed to a 24-bit/192kHz digital filter and then to a pair of balanced 24-bit/192kHz digital-to-analogue converters (DACs). Conventional players use one DAC for both channels and convert the current output of the DACs to voltage, a process that invariably causes signal distortion. Instead, the Cipher uses one DAC per channel and feeds the native balanced current output directly to Krell Current Mode circuitry. The sonic penalties of current-to-voltage conversion are thus gracefully avoided.
By using balanced DACs, the Cipher maintains a dual differential balanced signal from the DACs all the way to the output connections. This lowers distortion and improves signal-to-noise ratio to their maximum levels. Core Krell technologies of discrete, complementary, direct-coupled circuitry are used throughout the surface-mount-based output stage. Evolution CAST and balanced connections are included for optimal stereo playback. Multichannel SACD playback is also supported.
The backbone of all audio components is the power supply, which is often minimised in lesser players. Independent power supplies for the digital and analogue sections maintain signal isolation between these critical circuit areas. The Cipher linear power supply is sourced directly from the designs used in Krell Evolution e-Series amplifiers. This massive design preserves the dynamic contrasts that can get muted in players using switching or digital power supplies.
Price and Availability
The Krell Cipher SACD/CD player is available from June, priced at £12,000 in black or silver.
Specifications
Frequency response 20 Hz to 20 kHz +0.0, -0.25 dB
Signal to noise ratio “A” weighted 112 dB
THD 20 Hz to 20 kHz, < 0.005% dB
Output Level 2Vrms (single-ended)
4Vrms (balanced)
Power Consumption 61 W
Analog Audio outputs 1 pr. CAST via 4-pin bayonet connectors
1 pr. balanced via XLR connector
6 single-ended via RCA connector
Digital Audio outputs 1 S/PDIF via RCA, 1 EIAJ optical via TosLink
Remote Control 1 Wireless IR Remote
1 Remote IR sensor input via a 3-conductor 3.5 mm connector
Control inputs 1 RS-232 port via a 9-pin D-subminiature connector
1 12 VDC trigger input via 3.5 mm connector
1 Krell CAN Link via an RJ-45 connector
Control outputs 1 12 VDC trigger output via 3.5 mm connectors
Dimensions 17.3 in. W x 6 in. H x 17.3 in. D
43.8 cm W x 15.3 cm H x 43.8 cm D
Weight Shipped: 37 lbs., 16.8 kg
Unit only: 29 lbs., 13.2 kg
QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
WiiM Sound Lite Smart Speaker in white WiiM Sound Lite Smart Speaker in white
WiiM's original smart speaker sheds features to hit a lower price point ($229) for those who can live without a touch display and voice...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Brooklyn-based Ohm Acoustics have been manufacturing loudspeakers for almost 48 years. A deep dive by the Budget Audiophiler.
Loudspeakers
Orange, CT – September 2005 — Krell Industries is meeting the stylistic desires of its demanding clientele by releasing the popular Resolution Series loudspeakers...
The new Evolution lineup of products builds on the design and manufacturing excellence realized with the Evolution One and Two. Orange, CT — February...
Orange, CT — October 2006 — Krell Industries proudly announces shipping of the Evolution 403 and 900 amplifiers from their recently introduced Evolution series....
KRELL APPOINTS NEW NORTHWEST REGION ACCOUNT MANAGER Retail industry vet hired to grow new and existing accounts on the west coast. Orange, CT —...
Krell just released the S-550i Integrated Amplifier, which upgrades the performance of their S-300i integrated amp. The new S-550i delivers 275-watts of output, with...
Krell just released a state-of-the-art 7.1-channel A/V processor called Foundation, which decodes the latest lossless audio formats, offers extensive digital switching, 3DTV pass-through, and...
Krell announced a high-resolution digital audio streaming player for audiophiles who demand up to 192kHz/24-bit sonic purity. The Wi-Fi-equipped Connect Stream Player is available...
