Koss BT540i Bluetooth Headphones Debut
Koss today released the $200 BT540i Wireless Bluetooth headphones, which feature NFC pairing, aptX, and dual-microphones to reduce background noise during calls. Easy to locate, on-board controls allow listeners to quickly navigate through songs, play or pause music, volume-up, volume-down, and answer incoming calls.
The BT540i Wireless Bluetooth Headphones are outfitted with the all-new precision-tuned Koss PLX40 Dynamic Elements featuring crisp highs, robust mids and smooth lows, perfect for personal listening. Premium leather memory foam cushions close gaps around the ear, creating the perfect seal with an incredibly comfortable fit.
The built-in lithium-ion battery delivers more than 8 hours of listening time on a single charge. A detachable audio cable is included and can be used as a bypass should the battery run out. The BT540i folds flat and comes with a travel case for easy portability. Also included is a USB cable for on-the-go charging.
Price and Availability
The Koss BT540i Wireless Bluetooth Headphones are available immediately for $199.99.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
