Knoll HDP1100 and HDP1200 DLP Projectors
KONICA MINOLTA DIGITAL CAMERA
1080P HD projectors demonstrate Knoll’s outside-the-box ingenuity — in performance and installation
Knoll Systems of Richmond, BC announces the new projector that installers and integrators have been waiting for. Finally, a manufacturer has realized what it’s like to sweat away — hour after hour in a customer’s home, while they watch you feverishly tweak the knobs off a projector trying to get the set-up just right. Well, with the new HDP1100 and HDP1200 projectors — sweat no more.
Over the years, Knoll Systems has become known for products that are clever in design and installation-friendly. Once again this is proven true – with these new projectors, installers can be confident they can take a Knoll HD projector right out of the box, install it, zoom and focus, and it will look amazing.
The HDP1100 and HDP1200 are the first projectors from Knoll that have truly been built from the ground up by Kevin Knoll himself and the Knoll Systems’ team. These 1080p projectors are pre-tweaked to ISF perfection so they are out-of-the-box beautiful. Now you can sit up close and watch your favorite movies without any jaggies or bother. These full HD 1080p projectors will delight even the most demanding videophile with brilliant, deep and undeniably rich images. You’ll soon see that every moment spent watching your favorite movie or big game projected in true High Definition is a well-deserved indulgence.
According to Richard Hanson, Knoll VP Sales and Marketing, “The HDP1000 series projectors have met with high approval — from installers who are thrilled with the easy set-up — to experienced video enthusiasts who are amazed with the rich, dynamic, detailed picture. The HDP1100 and HDP1200 combine terrific installation flexibility and videophile performance in one compact, sleek package.”
Knoll HDP1100 and HDP1200 Projectors Rear Panel
The HDP1100 & HDP1200 boasts a native resolution of 1920 x 1080, is fully DTV compatible, and will accept and display all ATSC HDTV formats including 720p, 1080i and 1080p. The light output is 950 ANSI lumens with a contrast ratio up to 4400:1, The high-speed 7-segment color wheel virtually eliminates “rainbows” and other disturbing motion artifact problems. Combined with the super powerful Knoll signal processing these projectors deliver an image that specs cannot fully describe. Your family and friends can now experience the thrill of top-quality digital theater in your home at any time.
What used to cost hundreds of dollars – full factory calibration — has already been accomplished and is therefore included in each Knoll Systems Projector right out of the box. An all-glass Nikon multi-element lens, available in either a short throw (HDP1100) or the Long throw version (HDP1200) will enable the appropriate projector to match up well with any room size.
The installation of these new models is simplified further with the 2-HD lens shift. For unusual installation flexibility, Knoll incorporates both vertical and horizontal adjustments so the projector can be placed up or down and / or right or left of the screen’s center. Most other home theater projectors only offer horizontal lens shift. 2-HD Lens Shift makes projector placement easier, without sacrificing superior video quality. Installation is faster and easier and enables placement of the projector where it is most aesthetically pleasing. HDP1000 Series Projectors include all the best features, packed into one projector!
Most movies are filmed in aspect ratios from 2.35:1 to 2.40:1, (also known as Cinemascope). The HDP1100 & HDP1200 feature built-in scaling support to allow these images to be viewed at the highest possible resolution, called anamorphic. This is at least 30% greater resolution than that of a 1080p plasma or direct view LCD and requires an anamorphic lens, available separately.
Here’s a summary of the HDP1100 and HDP1200’s notable specifications and abilities:
  • Knoll Color Tuning and gamut time-saving calibration for easy-out-of-the-box WOW set-up!
  • 1080p DLP MaxPlay™ Processing and native 4400:1 contrast ratio.
  • Nikon Long and Short throw lenses
  • Knoll Dynamic Black™ for superior Contrast and brightness true to life black levels
  • 2-HD™ lens shift featuring both horizontal and vertical ultra wide bias adjustment to make any installation aesthetically pleasing, yet fast in any room with a challenging ceiling height
  • Built-in scaling support for 2.35:1 aspect ratio to mate with Panamorph anamorphic lens system
  • 2000-hour bulb life
  • Knoll 2 Year warranty with Quick-fix QF-100 (an available optional expedited replacement plan).
Pricing & Availability:
The new HDP1100 and HDP1200 are available immediately. The suggested retail price of the HDP1100 (with short throw lens) is $5999.00 while the HDP1200 (long-throw lens) is $6799.00 (US). Readily available through Knoll Systems distributors and Knoll Authorized Resellers.
Knoll Systems has designed and manufactured top-quality home theater and custom installation products for over 20 years. As the leader in volume controls, baluns technology, High Definition, projectors and other vital components for home theater and custom installation professionals worldwide. Knoll has offices in Denver Colorado, Point Roberts Washington, United States. Its corporate headquarters, engineering and main manufacturing are located in Richmond, BC, Canada.
Placing record on Turntable PP-1 from above
Are you one of those people who hates having to install a phono cartridge? The Waiting for Ideas PP-1 might be exactly what you're...
EE1 Plus with Cable EE1 Plus with Cable
Audio Cables
At £600, the EE1 Plus is designed to reduce interference and noise on wired networks, but do you really need it?
Michell Audio Apollo Phono Preamplifier and Muse Power Supply Michell Audio Apollo Phono Preamplifier and Muse Power Supply
Does the Michell Audio range of high-end turntables finally have a complementary phono pre-amplifier to match its capabilities? The Michell Apollo looks ready to...
Optoma Photon Go UST Projector Black Optoma Photon Go UST Projector Black
With an RGB triple laser light source, Google TV, built-in battery, and low price, the Photon Go might be a great home entertainment option.
Shanling EH2 Headphone Amplifier and DAC Shanling EH2 Headphone Amplifier and DAC
Forte Distribution previews Shanling's $399 EH2 DAC Headphone Amp for CanJam Attendees
FiiO FT7 Open-back Planar Magnetic Headphones Angle FiiO FT7 Open-back Planar Magnetic Headphones Angle
The FiiO FT7 Open-back Planar Magnetic Headphones will debut at the Bristol Hi-Fi Show and CanJam NYC this weekend.
Ultimate Man Cave Gift Guide 2025
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
