Klipsch The Three Wireless Speaker Gets Google Assistant
Klipsch Heritage The Three is a high-end table-top wireless speaker with Google Assistant built-in for $499.
Klipsch Heritage The Three Wireless Speaker With Google Assistant
“Hey Google” Voice Activated Retro Speaker
Klipsch recently released their next generation Heritage Wireless table-top wireless speaker called The Three with the Google Assistant built-in for $499. Competing at the high-end of voice-assistant speakers, The Three combines mid-century modern design, premium materials such as real wood veneer, and aluminum switches and knobs, and Bluetooth wireless technology.
Audiophiles will appreciate its 92kHz / 24-bit decoding for flawless reproduction of high resolution audio tracks on services that support high resolution audio. Plus, it’s multi-room ready if you want to buy more than one.
Klipsch Heritage The Three with Google Assistant Speaker Rear View
With Chromecast and Google Assistant built-in, it can easily play music, find answers on Google Search, manage everyday tasks, and control smart devices around your home—just by using your voice. Listen to your favorite song, find a delicious brownie recipe, or check your commute to work. Just start by saying “Hey Google” to start a conversation.
Like the speaker, but don’t want Google Assistant listening via the microphone? Klipsch does offer a standard version of The Three that only has Bluetooth. Unfortunately, you won’t say any money.
Features
MAX ACOUSTIC OUTPUT106dB (0.5M near field)
HIGH FREQUENCY DRIVERS2 x 2 1/4” (57.15mm) full range drivers
SUBWOOFER5.25” (133.4mm) long-throw woofer
2 x 5.25” (133.4mm) dual opposed passive radiators
ENCLOSURE TYPESealed
POWER60 watts continuous @ <1% THD 80 watts short-term peak power
FREQUENCY RESPONSE45Hz ~20kHz @ -3dB
INPUTSBluetooth
OUTPUTSnone
DIMENSIONS (WxHxD)13.7” (34.82cm) x 7” (17.78cm) x 8” (20.3cm)
VOLTAGE110/240 VAC
WEIGHT10.32lbs (4.7kg)
BUILT FROM2018
INCLUDED ACCESSORIESPower Cord
Price and Availability
Klipsch Heritage The Three with Google Assistant is available now for $499.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
With improved drivers and the addition of an active crossover option, the Klipschorn AK7 and La Scala AL6 are ready to take on all...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
The new Klipsch Forte IV loudspeakers feature updated cosmetics and the latest advancements in acoustic engineering, while maintaining the original charisma that made the...
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
