Klipsch Introduces The One Plus and Three Plus Bluetooth Tabletop Speakers
The One Plus and The Three Plus are retro styled tabletop wireless music systems to bring sound into any room.
Klipsch The One Plus Walnut Lifestyle
The high-end tabletop wireless loudspeaker category has been largely dominated over the past 5 years by Sonos, Ultimate Ears, Bluesound, Bowers & Wilkins, and Klipsch. Consumers have largely bought into the concept of multi-room audio by adding wireless speakers to each room that are connected through a control app accessible through their smartphones or tablets. It has proven to be a cost-effective way of using the same ecosystem throughout the home. Klipsch’s The One Plus ($249) and The Three Plus ($349) tabletop speaker systems feature real-wood veneers, rounded mid-century modern accents, and a smooth cloth grille.
What’s new?
The new models subtly refresh the retro design of previous models; The One II ($159) and The Three II ($199) were last updated in 2019 (as version II) and originally debuted in 2016. Each of the new “Plus” models add a USB-C input, update Bluetooth to version 5.3, and switch to a bass reflex enclosure from a sealed design.
Tip: The One II McLaren Edition debuted in early-2023 for those who like its racing design.
Klipsch The Three Plus Ebony Lifestyle
Klipsch The Three Plus shown is ebony. Both models are available in walnut or ebony (matte black).
Broadcast Mode
The newly integrated Klipsch Broadcast Mode is a unique feature available for the Klipsch One and Three Plus tabletop speakers. When activated, Broadcast Mode allows you to wirelessly connect up to 10 individual Klipsch One or Three Plus speakers, thus creating a seamless, encompassing multi-speaker sound experience.
Klipsch The Three Plus Ebony with Turntable Lifestyle
Only the Klipsch The Three Plus can connect to a turntable.
What’s Different?
Although both models look identical, the Three Plus is 1 to 2 inches bigger all around. The Three Plus is also turntable-ready with a built in-phono input, features larger drivers and offers double the amplifier power for more spacious rooms requiring greater output.
Klipsch The One Plus vs The Three Plus Rear in Walnut
Rear: The One Plus (top) vs The Three Plus (bottom)
Comparison
THE ONE PLUSTHE THREE PLUS
MSRP$249$349
MAXIMUM ACOUSTIC OUTPUT103dB106dB
HIGH FREQUENCY DRIVERS2.25” (57.15mm)
Full Range Drivers
2 x 2.25” (57.15mm)
Full Range Drivers
4.5” (114.3mm)
Woofer
5.25” (133.4mm)
Long-Throw Woofer
SUBWOOFER2 x 4.5” (114.3mm)
Dual Opposing Passive Radiators
2 x 5.25” (133.4mm)
ENCLOSURE TYPEBass ReflexBass Reflex
POWER60W120W
FREQUENCY RESPONSE55Hz – 20kHz45Hz – 20kHz
INPUTSUSB-C
Bluetooth® 5.3
3.5mm Miniplug (Analog)
USB-C
Bluetooth® 5.3
RCA (with Phono Pre-Amp) Optical
DIMENSIONS (WxHxD)12.52” x 6.1” x 6”
(31.8 x 15.5 x 15.2 cm)
13.98” x 8.38” x 7”
(35.5 x 21.3 x 17.8 cm)
WEIGHT 7.94lbs (3.6kg)10.58lbs (4.8kg)
FINISH OPTIONSWalnut, Matte BlackWalnut, Matte Black
INCLUDED ACCESSORIESPower CordPower Cord
Klipsch The One Plus Walnut Top with App
The One Plus in Walnut connected to Klipsch Connect App.
“These new speakers take a step-up in every aspect: connectivity is upgraded with USB-C, Bluetooth 5.3 and Klipsch Connect App compatibility; the design incorporates upgraded wood finishes and a rounded shape; and finally, acoustics took a step-up with next generation drivers and amplifiers,” said Vlad Grodzinskiy, Director of Product Development.
Price & Availability
1 Comment
1 Comment
  1. ORT
    September 25, 2023 at 5:56 pm
    Klipsch is my personal favourite for home speakers. But…Everyone I know has a big but so let’s talk about this one.
    The nicest desktopish Bluetooth speaker I own is made by Marshall. It is the Stanmore II and I bought it several years ago because of what it has. Bluetooh? Yes…But it also has WiFi and Wifi is mo’ bettah fo’ my needs.
    I use it to play Amazon Music when I do not want to turn on the HEOS speakers in the room. It plays music just fine and looks pretty good doing it. I have even sent *GASP* a signal from a *DOUBLE GASP* Crosley C6B-MA (with aftermarket acrylic platter!) to the Marshall and it did so quite well.
    I just like having the convenience of WiFi as I also play my choice for the Great American Songbook on the interwebs, “The Great American Songbook Radio Station” out of the Netherlands!
    If Klipsch ever does a WiFi capable speaker like one of these I will gladly consider buying one. If not for me, then for someone I care about. Kilpsch has the look. So too does my Marshal Stanmore II but it also has the WiFi.
    Maybe Klipsch already makes a similar speaker with WiFi?!
    ORT
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
With improved drivers and the addition of an active crossover option, the Klipschorn AK7 and La Scala AL6 are ready to take on all...
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
The new Klipsch Forte IV loudspeakers feature updated cosmetics and the latest advancements in acoustic engineering, while maintaining the original charisma that made the...
Sonos ventures deeper into the business and commercial landscape with a variation of its ERA 100 wireless speakers with features specifically designed for that...
Klipsch, Onkyo and Integra have been swept up in Gentex's acquisition of VOXX International. Can they all survive in 2025?
Daily Deals
Our favorite soundbars on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
Digital Music Systems
At $649, the REVO SuperCD includes digital music streaming, Bluetooth 5.1, global radio, podcasts with dedicated app, and remote.
