Klipsch RP-15PM Powered Wireless Speakers
Klipsch Reference Premiere R-15PM
Klipsch just introduced their first powered stereo speakers, which can be used wirelessly with Bluetooth or wired to a TV, turntable, or PC. The new Klipsch Reference Premiere R-15PM powered monitors bundle an integrated phono pre-amp, Bluetooth wireless technology, digital optical, analog RCA and USB audio inputs into a $500 stereo speaker solution. The R-15PM powered monitors also incorporate individual, ultra-low noise amplifiers custom designed to maximize system performance and eliminate the need for an A/V receiver. The speakers offer a wired sub output to further enhance the speakers’ low frequency. The R-15PM’s dedicated IR remote allows easy access to system features such as dedicated source selection, track controls and play/pause options.
Klipsch R-15PM Front with Remote
As with the all Reference loudspeakers, the R-15PM powered monitors feature proprietary 90°x90° Hybrid Tractrix Horn technology coupled with Linear Travel Suspension (“LTS”) titanium tweeters to produce the most effective release of sound waves for clean, natural listening experiences. The LTS tweeters ensure minimized distortion for enhanced, detailed performance. Reference Premiere R-15PM powered monitors fully embody the ideals of Klipsch design philosophy: low distortion, high efficiency, flat frequency response, broad dynamic range and controlled directivity.
Klipsch R-15PM Back
Providing remarkable low-frequency response with minimal cone breakup or distortion are the speakers’ copper-
spun IMG woofers. The woofers are coupled with, ceramic motor structures—a design that when paired with Tractrix Horn-loaded LTS tweeters combines for speaker efficiency that is highest in its class. Unique materials have been applied in the ongoing pursuit of ultra-low distortion design. The horn’s outer layer is silicon-based rubber, which eliminates resonance of the horn housing, improving detail and resolution.
Price and Availability
The Klipsch Reference RP-15PM powered monitors will be available January 2016 for $499/pair (US MSRP).
Specifications
FREQUENCY RESPONSE
62Hz – 24kHz +/- 3dB
LOW FREQUENCY EXTENSION
54Hz
CROSSOVER FREQUENCY
1800Hz
HIGH FREQUENCY DRIVER
1″ (2.54cm) Aluminum diaphragm compression driver mated to 90° x 90° square Tractrix Horn
LOW FREQUENCY DRIVER
5.25″ (13.3cm), copper spun magnetically shielded IMG woofer
AMPLIFIER POWER
50 Watts per channel
ENCLOSURE MATERIAL
MDF
ENCLOSURE TYPE
Bass-re ex via rear- ring port
INPUTS
  • 1 x pair of RCA phono level inputs with switch for Phono/ Line input versatility (Phono Preamp with ground screw terminal)
  • 1 x USB digital audio from a PC or Mac single RCA line level output for connection to sub.
  • 1 x Digital optical
  • 1 x 3.5mm mini jack line level
  • Bluetooth wireless technology
HEIGHT
12.5″ (31.8cm)
WIDTH
7” (17.8cm)
DEPTH
8.11” (20.6 m)
WEIGHT
10.3 lbs (4.67kg)
FINISH
Brushed Black Polymer Veneer
BUILT FROM
2016
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
With improved drivers and the addition of an active crossover option, the Klipschorn AK7 and La Scala AL6 are ready to take on all...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
The new Klipsch Forte IV loudspeakers feature updated cosmetics and the latest advancements in acoustic engineering, while maintaining the original charisma that made the...
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
