Earbuds & In-Ear Headphones
Klipsch Reference R6m In-Ear Headphones
Klipsch Reference R6m in-ear monitor
Klipsch just announced the Reference R6m in-ear monitor, a $100 universal-fit headphone for mobile devices. Its sleek construction of aluminum and elastomer make for a lightweight, durable and comfortable headphone while flat, tangle-resistant cabling allows for hassle-free storage and transport.
The Reference R6m in-ear monitor is specifically engineered to work with any mobile device to provide a front-stage pass to music collections. The single-button remote and mic operates seamlessly with Apple, Android, Windows and BlackBerry devices while also providing functionality with the latest consoles like Xbox One and PS4 amongst many others.
The Reference Series in-ear monitors are equipped with Klipsch’s patented oval ear tips that naturally fit the contours of the ear canal providing hours of comfortable, long-term wear. The soft silicon tips reduce ear fatigue to provide the ideal seal for noise-isolation (or passive noise-cancellation), blocking out almost all ambient noise and providing excellent bass.
The Reference Series in-ear monitors produce the brand’s signature sound via a 6.5-milimeter dual magnet micro-speaker. This technology provides for a broad frequency range and acoustic detail for the most strikingly realistic sound reproductions of music libraries.
Price and Availability
The Klipsch Reference R6m in-ear monitor is available now for $99.99 in a black finish and comes complete with carrying case, clothing clip and four different sized ear tips.
Specifications
STYLE: In-Ear Monitor
FREQUENCY RESPONSE: 10Hz-19kHz
SENSITIVITY: 110dB
IMPEDANCE: 18 ohms
DRIVER DESIGN: Dual Magnet, Dynamic Moving Coil Micro Speaker
NOISE ISOLATION: -22
INPUT CONNECTIONS: 3.5 mm
DRIVER DIAMETER: 6.5 mm
DIMENSIONS (PACKAGING): 7.9˝ H x 4.5˝ W x 1.3˝ D
WEIGHT: 15.2 g
COLORS: Black
Networking
In-Wall Speakers
With improved drivers and the addition of an active crossover option, the Klipschorn AK7 and La Scala AL6 are ready to take on all...
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
The new Klipsch Forte IV loudspeakers feature updated cosmetics and the latest advancements in acoustic engineering, while maintaining the original charisma that made the...
Klipsch, Onkyo and Integra have been swept up in Gentex's acquisition of VOXX International. Can they all survive in 2025?
Daily Deals
Our favorite soundbars on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
In this episode the eCoustics teams reveals its Best in Show product awards from CEDIA Expo 2024 across 17 different categories.
At $8,498/pair, only a limited number Klipsch + Ojas kO-R1 two-way multicelled loudspeakers will be handcrafted in Hope, Arkansas.
