Klipsch Reference Premiere II Loudspeakers
The Klipsch Reference Premiere Series has been completely revamped for 2022 and the new RP-600M II is making waves already.
Klipsch Reference Premiere II Speaker Series
Klipsch today introduced their new 2022 Reference Premiere II Loudspeaker line-up for home theater and stereo listening. Although it’s the third generation of the series, Klipsch is adding a “II” to all previous model numbers to signify the new line.
There are 11 new models in total ranging from $599 to $2,998/pair.
The Reference Premiere II series improves upon the previous generation by adding larger proprietary Tractrix® horn technology said to enhance imaging and dynamics. Klipsch signature copper Cerametallic™ woofers with aluminum Faraday rings and Tractrix ports provide powerful low frequencies while minimizing distortion and maximizing efficiency. An exclusive Linear Travel Suspension (LTS) titanium tweeter maximizes dynamics, said to bring out details in performances.
Klipsch Reference Premiere RP-500M II vs Reference RP-50M
Klipsch Reference Premiere RP-500M II (left) vs Reference R-50M (right).
There is a height difference with Reference model being taller (see comparison below)
Readers may note, Klipsch also updated their lower priced Reference Loudspeaker (not Premiere) line for 2022 as well. Although they resemble one another, and share similar technology the step-down Reference line uses different woofers, crossovers and tweeters, opting for Aluminum instead of Titanium tweeters and Copper instead of Cerametallic woofers.
For about 30% greater cost, the Reference Premiere II offers premium build quality and optional walnut finish option. Premiere II speakers have reinforced cabinet bracing, aluminum binding posts, cast aluminum feet, and discrete Dolby Atmos connections that allow for easy and refined elevation speaker integration. Signature Klipsch copper trim rings accentuate the tweeter and woofer, which can also be concealed by sturdy yet flexible magnetic grilles.
The highly anticipated Klipsch RP-600M II which replaces the award-winning RP-600M, is likely to sell out very quickly if it offers a significant level of improvement over the previous model.
Center Speakers
Surround Speakers
All Reference Premiere loudspeakers are available in ebony or walnut.
Comparisons
Comparing Reference Premiere (RP) vs Reference (R) Bookshelf Speakers
RP-600M IIRP-500M IIR-50MR-40M
MSRP$749/pair$599/pair$399/pair$279/pair
FREQUENCY RESPONSE44-25kHz ±3dB50-25kHz ±3dB58Hz – 21kHz ±3dB71Hz – 21kHz ±3dB
SENSITIVITY*94.5dB @ 2.83V / 1m*92dB @ 2.83V / 1m*92 dB (In-Room)91 dB (In-Room)
POWER HANDLING (CONT/PEAK)100W/400W75W/300W75W/300W50W/200W
NOMINAL IMPEDANCE8 Ohms Compatible8 Ohms Compatible8 ohms Compatible8 ohms Compatible
CROSSOVER FREQUENCY1500Hz1530Hz1560 Hz1770 Hz
HIGH FREQUENCY DRIVER1″ Titanium LTS Vented Tweeter with Hybrid Cross-Section Expanded Tractrix® Horn1″ Titanium LTS Vented Tweeter with Hybrid Cross-Section Expanded Tractrix® Horn1″ Aluminum LTS tweeter mated to a 90 x 90 square Tractrix® Horn1″ Aluminum LTS tweeter mated to a 90 x 90 square Tractrix® Horn
LOW FREQUENCY DRIVER6.5″ Cerametallic Cone Woofer with Faraday rings5.25″ Cerametallic Cone Woofer with Faraday rings5.25″ spun-copper TCP woofer4″ spun-copper TCP woofer
ENCLOSURE MATERIALMDF (Internally Braced)MDF (Internally Braced)MDFMDF
ENCLOSURE TYPEBass Reflex via rear-firing Tractrix® PortBass Reflex via rear-firing Tractrix® PortBass-Reflex via rear-firing portsBass-Reflex via rear-firing ports
INPUTSDual aluminum binding posts/bi-wire/bi-ampSingle aluminum binding postsSingle Gold Plated Binding PostsSingle Gold Plated Binding Posts
HEIGHT INCHES (MM)15.75″ (40.0 cm)13.56″ (34.4 cm)13.9″ (354 mm)11.7″ (298 mm)
WIDTH INCHES (MM)7.95″ (20.2 cm)6.81″ (17.3 cm)7″ (178 mm)5.8″ (146 mm)
DEPTH INCHES (MM)13″ (33.0 cm)10.65″ (27.0 cm)9″ (229 mm)8.5″ (216 mm)
PRODUCT WEIGHT LBS (KG)18.1lb (8.20kg)13.1lb (5.95kg)11 lbs (5 kg)7 lbs (3.2 kg)
FINISHEbony, WalnutEbony, WalnutBlack Textured Wood Grain VinylBlack Textured Wood Grain Vinyl
*SPL at 1M, half-space anechoic with 2.83V input
Reference Premiere Floorstanding Speakers
RP-8060FA IIRP-8000F IIRP-6000F IIRP-5000F II
MSRP$2,998/pair $1,798/pair$1,498/pair$1,198/pair
FREQUENCY RESPONSE35-25kHz ±3dB35-25kHz ±3dB38-25kHz ±3dB40-25kHz +/- 3dB
SENSITIVITY*98dB @ 2.83V / 1m*98dB @ 2.83V / 1m*96dB @ 2.83V / 1m*95dB @ 2.83V / 1m*
POWER HANDLING (CONT/PEAK)150W / 600W150W / 600W125W/500W100W / 400W
NOMINAL IMPEDANCE8 Ohms Compatible8 Ohms Compatible8 Ohms Compatible8 Ohms Compatible
CROSSOVER FREQUENCY1630Hz1630Hz1770Hz1900Hz
HIGH FREQUENCY DRIVER1″ Titanium LTS Vented Tweeter with Hybrid Cross-Section Expanded Tractrix® Horn1″ Titanium LTS Vented Tweeter with Hybrid Cross-Section Expanded Tractrix® Horn1″ Titanium LTS Vented Tweeter with Hybrid Cross-Section Expanded Tractrix® Horn1″ Titanium LTS Vented Tweeter with Hybrid Cross-Section Expanded Tractrix® Horn
LOW FREQUENCY DRIVERDual 8” Cerametallic Cone Woofers with Faraday ringsDual 8” Cerametallic Cone Woofers with Faraday ringsDual 6.5″ Cerametallic Cone Woofers with Faraday ringsDual 5.25″ Cerametallic Cone Woofers with Faraday rings
ENCLOSURE MATERIALMDF (Internally Braced)MDF (Internally Braced)MDF (Internally Braced)MDF (Internally Braced)
ENCLOSURE TYPEBass Reflex via dual chamber rear-firing Tractrix® PortsBass Reflex via dual chamber rear-firing Tractrix® PortsBass Reflex via dual chamber rear-firing Tractrix® PortsBass Reflex via dual chamber rear-firing Tractrix® Ports
INPUTSDual aluminum binding posts / bi-wire / bi-ampDual aluminum binding posts / bi-wire / bi-amp with Dolby Atmos® passthroughDual binding posts / bi-wire / bi-ampDual aluminum binding posts / bi-wire / bi-amp with Dolby Atmos® passthrough
HEIGHT INCHES (MM)43.11″ (109.5 cm)43.10″ (109.5 cm)39.60″ (100.6 cm)36.10 (91.7 cm)
WIDTH INCHES (MM)10.84″ (27.5 cm)10.84″ (27.5 cm)9.29″ (23.6 cm)8.15″ (20.7 cm)
DEPTH INCHES (MM)20.80 (52.8 cm)18.25″ (46.3 cm)17.57″ (44.6 cm)14.75″ (37.5 cm)
PRODUCT WEIGHT LBS (KG)75.7 lb (34.35kg)61.4lb (27.85kg)49.4lb (22.4kg)38.6lb (17.55kg)
FINISHEbony, WalnutEbony, WalnutEbony, WalnutEbony, Walnut
INCLUDED ACCESSORIESInjection molded feet & screws
2 Comments
2 Comments
  1. alfred
    May 18, 2022 at 12:09 am
    Question, actually: Can the Klipsch Premiere be installed against the back wall as pictured?
  2. ORT
    May 18, 2022 at 1:11 am
    I very much like Klipsch speakers and these new ones are packed with the familiarity that makes a family reunion worth the long drive. How so?
    Familiarity breeds comfort. I have two pair of Klipsch towers and a pair of their Atmos add-ons for the front L & R. I would so like to own either a pair of the new RP-600Mii or the previous models. In Piano Black, please. I am far from a sensitive individual but I do like speakers that are.
    Thank you for whetting my audio appetite. Hopefully I read as being extra pretentious. Sheesh…LOL!
    Again, thanks!
    ORT
    ORT
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
With improved drivers and the addition of an active crossover option, the Klipschorn AK7 and La Scala AL6 are ready to take on all...
At $18,000 per pair, the TAD ME1TX feature an upgraded CST Driver and other refinements.
Zu Audio hints of new products to debut at Capital Audio Fest from November 8-10, 2024, but photos and details are scarce.
The 300 series implements some of the technologies used in the flagship Corinium speakers at a more affordable price point
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
The new Klipsch Forte IV loudspeakers feature updated cosmetics and the latest advancements in acoustic engineering, while maintaining the original charisma that made the...
Klipsch, Onkyo and Integra have been swept up in Gentex's acquisition of VOXX International. Can they all survive in 2025?
