Klipsch ProMedia 2.1 Heritage Speaker System Goes Back to the Future
Klipsch announces the Klipsch ProMedia 2.1 Heritage Multimedia Speaker System with Tractrix Horn technology and a great retro look.
Klipsch ProMedia Heritage 2.1 Speaker System Walnut
Klipsch has adopted a classic retro look for its latest product, the ProMedia 2.1 Heritage Multimedia Speaker System
For Klipsch fans, the exterior cabinet design and grill bring back memories of the legendary Heresy and Forte speakers.
The Klipsch Heritage Series has delivered performance, accolades, and tremendous sales success for the venerable brand and we hope the new ProMedia 2.1 isn’t a clever marketing play but a genuinely great sounding system for only $350 USD.
Behind the look, the ProMedia Heritage is a 2.1 channel system that consists of two compact bookshelf loudspeakers combined with a compact, yet powerful 8-inch subwoofer. Classified as a multimedia speaker system, it can be used with a PC for gaming and music, as a music-only system, or with your TV as an alternative to a soundbar for watching shows and movies.
Tip: To use the system with a TV, the TV needs to have analog audio outputs.
Klipsch ProMedia Heritage 2.1 Speaker System on Desktop
The system utilizes powered speakers. You don’t have to connect them to an amplifier or receiver as the two speakers and subwoofer have their own built-in amps. For physical sources, you connect a stereo audio cable to the primary satellite speaker. Then that speaker distributes the audio signals to the secondary speaker and subwoofer via provided cables.
Klipsch ProMedia Heritage 2.1 Speaker System No Grilles
The ProMedia Heritage doesn’t have built-in Wi-Fi, so you can’t stream to it directly from the internet. However, the system does have built-in Bluetooth which allows users to stream music from their music library or favorite streaming services from compatible devices, such as smartphones. You can also connect physical sources to the system via the provided analog audio input.
Tip: If using a turntable, depending on its connectivity options, you might have to place a phono preamp between the turntable and the speaker system.
Core Features
Peak System Power: 220 watts, Satellite Speakers: 35 watts each, Subwoofer: 150 Watts.
System Frequency Response: 29Hz to 20kHZ
Enclosure: Satellites (sealed box), Subwoofer (Bass-Reflex with rear Port).
Satellite Speaker Drivers: 1-inch soft dome tweeters mounted on Tractrix horns. Each speaker also features a 3-inch long-throw woofer.
Subwoofer Driver: 8-inch long-throw with Polyfiber cone.
Inputs (Wired): Analog Stereo RCA (3.5mm to RCA adapter included if needed). USB Type-A.
Inputs (Wireless): Bluetooth (version not specified)
Dimensions
Satellite Speakers (each): 8 x 5.5 x 4.3-inches
Subwoofer: 12 x 10 x 15-inches
Weight
Satellite Speakers (each): 1.5 lbs
Subwoofer: 14 lbs
Finish: Walnut or Black Ash
Klipsch ProMedia Heritage 2.1 Speaker System Black
Pricing and Availability
The Klipsch ProMedia Heritage 2.1 is priced at $349.00 or less at Klipsch.com, Costco, and Amazon in black ash or walnut finishes.
2 Comments
2 Comments
  1. ORT
    May 11, 2022 at 10:01 pm
    Superb! It warms the heart and stirs the soul to see a manufacturer pay homage to its own storied history and STYLE.
    Well done, Klipsch! Well done, indeed.
    I may not need one, but I definitely DESIRE (“want” is not nearly as passionate as is required in this instance) one.
    ORT
    • Hector Dy
      June 12, 2023 at 4:10 am
      The quality is the best! I have 2 unites promedia 2.1 THX.what is higher volume to this? I want louder than this but the sound quality is better or the same 110v to 220 for Philippines
      My email add.is hectorcdy@yahoo.com
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
With improved drivers and the addition of an active crossover option, the Klipschorn AK7 and La Scala AL6 are ready to take on all...
For 2025, the Audioengine A2+ now includes Bluetooth 5.3, 24-bit audio, and USB-C connectivity - still at an affordable price.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
The new Klipsch Forte IV loudspeakers feature updated cosmetics and the latest advancements in acoustic engineering, while maintaining the original charisma that made the...
At $279.99, the Creative Pebble Nova desktop speakers feature coaxial drivers with both wireless and wired connectivity.
Klipsch, Onkyo and Integra have been swept up in Gentex's acquisition of VOXX International. Can they all survive in 2025?
Daily Deals
Our favorite soundbars on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
