Klipsch Mode M40 Noise-Cancelling Headphones
The new Klipsch Mode M40 over-ear headphones exude both fashion and luxury, while offering high-grade leather cups for unwavering comfort and state-of-the-art, active noise-cancelling (ANC) that lasts up to 45 hours on a single battery. Unique to Klipsch’s ANC model, the Klipsch Mode M40 allows for uninterrupted listening potential, as it continues to function as a high-performance stereo headphone even without battery power.
The advanced three-button remote and mic offers full control of iPhone, iPod touch and iPod models, while allowing for seamless control of music and phone calls. Its dual drivers include a moving coil 40mm woofer providing deep bass and a 15mm tweeter bringing crisp, clean highs. Plus the M40’s active crossover maintains a dynamic midrange.
Built from the same durable materials used in high-end eyewear and accompanied with cloth cables like those used in premium hi-fi systems, the M40 noise cancelling headphone proves to be Klipsch’s most luxurious and fashion-forward model to date.
Specifications
  • DESIGN: Over-ear, Active Noise-Cancelling
  • DIMENSIONS: Driver diameters: 40 mm/15 mm
  • DRIVE COMPONENTS: Dual-drivers: Dynamic Moving Coil 40 mm and 15 mm speakers
  • FEATURES: Passive Cross-over Network, Active Noise Reduction, Mic+3-button remote
  • FINISH: Copper/black
  • FREQUENCY RESPONSE: 20 Hz – 20 kHz
  • INPUT CONNECTIONS: 3.5mm
  • INPUT IMPEDANCE: (@ 1kHz): 32 ohms
  • SENSITIVITY: (@ 1 mW, 15 mm): 97.5 dB
  • WEIGHT: .78 lbs (356 grams)
Price and Availability
The Klipsch Mode M40 noise-cancelling headphones will be available for $349.99 fall 2011.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
With improved drivers and the addition of an active crossover option, the Klipschorn AK7 and La Scala AL6 are ready to take on all...
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
The new Klipsch Forte IV loudspeakers feature updated cosmetics and the latest advancements in acoustic engineering, while maintaining the original charisma that made the...
Klipsch, Onkyo and Integra have been swept up in Gentex's acquisition of VOXX International. Can they all survive in 2025?
Daily Deals
Our favorite soundbars on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
In this episode the eCoustics teams reveals its Best in Show product awards from CEDIA Expo 2024 across 17 different categories.
At $8,498/pair, only a limited number Klipsch + Ojas kO-R1 two-way multicelled loudspeakers will be handcrafted in Hope, Arkansas.
