Klipsch Jubilee Floorstanding Horn-Loaded Loudspeakers: The Culmination of a Dream
The Klipsch Jubilee Celebrates 75 years of success and is the culmination of a lifelong dream. Paul W. Klipsch would have loved these.
Klipsch has started shipping their largest and most advanced loudspeaker in the company’s 75-year history. As the new flagship, the Klipsch Jubilee is the realization of the final project, founder Paul W. Klipsch (PWK) worked on before his death in 2002. It was his dream to create a fully horn-loaded speaker that would satisfy the most ardent audiophiles.
Originally intended to be the successor to the Klipschorn, PWK soon realized it was much more than that. Twenty-first century advancements in engineering and technology have allowed Klipsch to make his dream a reality.
Klipsch Jubilee Loudspeaker Walnut Angle
Klipsch Jubilee Loudspeaker in Walnut with Grilles On
An excerpt from PWK’s AES white paper, A Revised Low-Frequency Horn of Small Dimensions (paywall), reveals some of the loudspeakers history.
JAES Volume 48 Issue 10 pp. 922-929; October 2000
ROY DELGADO, JR., AES Member, AND PAUL W. KLIPSCH, AES Member Klipsch LIC, Hope, AR 71801, USA
Published October 1, 2000
More than 50 years after the introduction of the KLIPSCHORN, a revised low-frequency horn for the system is presented, which will return the system to a two-way design as originally envisioned by its inventor. How this was achieved is discussed with the support of data and results.
INTRODUCTION
Paul Klipsch's paper describing a low-frequency horn was first published in 1941 and subsequently re-printed in this Journal in 1979. The paper described the thoughts and reasoning behind the KLIPSCHORN low-frequency horn. Today, more than 50 years after its introduction, the low-frequency section of the system remains for the most part unchanged. The current loud-speaker is a three-way, fully horn-loaded system, which still commands respect in the company of most of today's high-end loudspeakers.
BACKGROUND
The advantages of horns are well known. Many designs have been implemented and some patented. The efficiency and the low distortion characteristics of properly engineered horn-loaded cabinets are not rivaled by vented or sealed systems. Horn-loaded low-frequency sections must be large to go down to any appreciable cutoff frequency. And small horn-loaded low-frequency sections have a high cutoff frequency, typically in the 60-100-Hz range. One major advantage of the current low-frequency unit is that it has a cutoff of 38 Hz and is still able to fit into most living rooms. It takes advantage of the fact that it operates in a corner(one-eighth space). Therefore it does not require the large mouth the same horn would need if it were to operate in full space. Because the driver is horn loaded, the amount of excursion it undergoes is reduced, and thus distortion is also reduced. A driver that is able to withstand 250 W of input power produces high sound pressure levels (SPLs) because of the efficient loading of the horn. The new low-frequency unit is to have all of this as well as the ability to go 200 Hz higher (1/2 octave) than the current low-frequency unit.
The New Klipsch Jubilee
The new 2022 Klipsch Jubilee is now the only speaker in the company’s 75-year history to surpass the legendary Klipschorn in its spot at the top of the Klipsch Heritage series.
The Klipsch Jubilee is a fully-horn loaded two-way loudspeaker, designed to deliver the ultimate listening experience. It incorporates the latest in acoustic developments to accomplish this feat, featuring a patented horn-loaded vented low frequency enclosure and an all-new horn-loaded compression driver.
Klipsch Jubilee Loudspeakers Pair Walnut Lifestyle
Each component is specifically optimized to operate in its individual pass-band, resulting in the Klipsch Jubilee being one of the most efficient commercially available loudspeakers.
Higher efficiency yields greater acoustic power, which is generated with considerably less effort. The result is the cleanest, most dynamic sound possible throughout the entire musical range.
Klipsch Jubilee Loudspeaker Black Lifestyle with Grille On
Horn-Loaded Vented System
The patented low frequency enclosure of the Klipsch Jubilee is designed to provide magnificent presence, by leveraging the efficiencies of both horn-loaded and vented systems. The typical vented system already increases the efficiency and sensitivity for extended low frequency performance.
Horn-loading this system allows the Klipsch Jubilee to be a staggering 10 to 20 times more efficient than a conventional loudspeaker. This results in unrivaled low frequency performance, maximizing output while minimizing distortion, for dynamic and clean bass.
Klipsch Jubilee Loudspeaker Walnut Side
High Frequency Compression Driver
The Klipsch Jubilee features an all-new large format compression driver with a 7” axiperiodic Titanium diaphragm. The single, large diameter diaphragm provides very wide bandwidth performance, eliminating the need for a mid-range driver – true to Paul Klipsch’s original Klipsch Jubilee design.
This wide bandwidth design lowers the crossover point below the critical vocal range to maximize clarity and accuracy. The axiperiodic design delivers a smooth response, while still maximizing output and minimizing distortion for a more effortless performance.
Klipsch Jubilee Active Crossover
Active Crossover
The Klipsch Jubilee features an external active DSP crossover network to ensure
the highest degree of accurate reproduction of sound. The DSP network adjusts
the phase and time delay of each acoustic component to eliminate acoustic phase cancellations and maximize output in the crossover region for truer-to-life sound.
The DSP network also provides the necessary EQ and gain adjustment to blend the two acoustic components together seamlessly. Designed for shelf or rack mount applications, the Klipsch Jubilee active crossover also features adjustable low frequency and high frequency trim levels to ensure a listening experience tailored to your room and personal taste.
Klipsch Jubilee Loudspeaker Walnut Back
Key Features
  • A patented, horn-loaded, vented, low frequency enclosure that delivers unrivaled dynamics and clean bass from its dual 12” woofers and three 4” ports.
  • An all-new, horn-loaded, compression driver with a 7” axiperiodic titanium diaphragm provides a wide bandwidth for seamless clarity and accuracy.
  • Each component is specifically optimized to operate in its individual pass-band, making it one of the most efficient loudspeakers on the planet.
  • An active crossover network ensures the highest degree of accurate, true-to-life sound reproduction through a built-in digital signal processor (DSP) and equalizer. It enables using separate amplifiers for the high frequency and low frequency speakers, eliminates phase cancellation in the crossover region and may be shelf or rack-mounted.
Klipsch Jubilee Loudspeaker Walnut Top
Specifications
FREQUENCY RESPONSE (+1.75 dB/- 3 dB) 8Hz – 20kHz
SENSITIVITY1 Avg. Sensitivity of HF – 110dB
Avg. Sensitivity of LF – 107dB
POWER HANDLING (CONT/PEAK) LF – 300W / 1200W
HF – 100W / 400W
MAXIMUM SPL 125 dB/1m (Using DSP)
NOMINAL IMPEDANCE LF – 8 ohms, minimum 3.5 ohms at 160Hz
HF – 16 ohms, miminum 7.6 ohms at 4.3kHz
CROSSOVER FREQUENCY 340 Hz
HIGH FREQUENCY DRIVER K-693 7” Titanium Diaphragm Compression Driver with 5” Voice Coil
LOW FREQUENCY DRIVER Dual K-283 12” Fiber-Composite cone woofers
ENCLOSURE MATERIAL MDF
INPUTS 5 way binding post
HEIGHT 69.5” (175.26 cm)
WIDTH 50.25” (127 cm)
DEPTH 30.25” (76.2 cm)
WEIGHT LF – 330 lbs (149.68 kg)
HF – 78 lbs (35.38 kg)
FINISH Black Ash, American Walnut
GRILLE Salt and Pepper Cloth
1 Sensitivity in average listening room
Klipsch Jubilee Loudspeaker Walnut Front Grille Off
Made in USA
Like the entire range of Klipsch Heritage speakers, Klipsch Jubilee speakers are designed and handcrafted in the USA and carry an unprecedented 10-year warranty. Each speaker is grain-matched using wood veneer panels from the same timber, resulting in a speaker pair that is virtually indistinguishable from the other.
Klipsch Jubilee Loudspeaker Black Grille off Lifestyle
Price & Availability
The Klipsch Jubilee loudspeakers are available now for $35,000/pair (USD) through Certified Klipsch Heritage dealers only in satin black ash or American walnut.
For more information: klipsch.com
About Klipsch Audio
In 1946 Paul W. Klipsch, inventor, acoustics pioneer and maverick, founded Klipsch Audio with the sole purpose of bringing the power, detail and emotion of the live music experience into his living room. Through the use of highly efficient speaker designs, handcrafted cabinetry and a thirst for real engineering breakthroughs – Klipsch, the great American loudspeaker company, was born in Hope, AR. Today, our diverse range of quality audio products includes speakers and headphones for almost any consumer and professional application – including cinema, whole-house, wireless, home theater and portable offerings. Honoring our founder’s legacy, Klipsch continues to be the legendary high-performance brand of choice for audiophiles and aficionados around the world. We are the Keepers of the Sound®
1 Comment
1 Comment
  1. Steven Denfeld
    June 3, 2022 at 9:56 pm
    Lordy, those have jazz kissa written all over them. I bet they sound divine!
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Our top floorstanding loudspeakers for 2025 come from Magnepan, Q Acoustics, KLH, Audiovector, and ATC—five brands delivering standout engineering, scale, and true high-end performance.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
Focal quietly drops the $699–$2,299 Omada speakers between Vestia and Theva, packing TAM tweeters and Slatefiber cones in a non-typical rollout but with good...
AUER Acoustics brings its very expensive VERSURA speakers to the US, featuring tankwood cabinets, refined design, and high-end engineering aimed at serious audiophiles.
Sept 18th at Common Wave Hi-Fi, Los Angeles hear the Klipschorn AK7 loudspeakers in a rare master class with Roy Delgado Jr. of Klipsch....
JBL unveils its new flagship 4369 Studio Monitors at the Tokyo International Audio Show for audiophiles and studios alike. Available Q1 2026, price TBA.
Only 25 numbered pairs will ever be made, finished in piano-gloss rosewood with satin-black detailing, engraved plaques and certificates of authenticity.
