Klipsch has introduced its first-ever headphones designed for Android, the Klipsch Image S4A in-ear headphones which allows for complete music and call control for relevant devices and tablets. After downloading the free Klipsch Control App, the headphone instantly becomes a fully functioning headset. With its single-button remote, users are able to play, pause and skip music tracks, answer and end incoming calls, and voice search. Boasting the same look and feel as the original Image S4, its patented ear tips ensure hours of comfortable, long-term wear and protective carrying case.
Price and Availability
The Klipsch Image S4A for Android in-ear headphones are compatible with devices running Android 2.1 operating system or higher and will be available for $99.99 fall 2011.
Specifications
- DESIGN: Dynamic Moving Coil Micro Speaker
- DIMENSIONS: 8.5mm diameter
- DRIVE COMPONENTS: Full range KG 25
- FREQUENCY RESPONSE: 10Hz – 19KHz
- INPUT CONNECTIONS: 3.5mm
- NOISE ISOLATION: -16
- NOMINAL IMPEDANCE: 18-ohm
- SENSITIVITY: 110db SPL/mW
See more about: In-ear Headphones, Klipsch
