Klipsch just introduced a white version of their Image ONE Bluetooth on-ear wireless headphones. Just like the original black version released a year ago, the Image ONE Bluetooth White utilizes Hi-Fi Bluetooth (A2DP) audio quality and aptX Codec for lossless streaming so users experience high-performance, uninterrupted listening. The headphone’s wireless capabilities are enabled via a built-in rechargeable battery; with wired connection still possible via the included direct connect audio cable. Large, easily-accessible controls are located on the right ear cup for controlling playlists and phone calls. Extensive research resulted in the ideal ergonomic placement of buttons so users’ hands naturally fall onto the controls.
Showcasing a sleek white finish with brushed aluminum and gray leather accents, the Image ONE Bluetooth White offers listeners comfortable ear cups featuring leather-wrapped memory foam. Enabling hours of listening pleasure and superior passive noise-isolation, the headphone blocks out ambient noise and provides enhanced bass. Its compact, collapsible design aids with storage and travel, as the ear cups can be folded flat into the headband. In addition to offering 10 hours of continuous talk and listening time from a paired Bluetooth device, roam up to 33 feet away and remain connected to your music and calls.
The on-ear headphones come with a compact travel case, direct connect audio cable, micro USB charging cable, 1/4″ adapter, airline adapter and two-year warranty. They should be compatible with any Bluetooth-enabled device.
Price and Availability
Klipsch Image ONE Bluetooth White headphones are available now for $249.99.
Specifications
- Bluetooth A2DP CODECS: SBC, AAC, aptX
- Bluetooth INPUT RATING: 5V DC, 0.5A
- Bluetooth PROFILES: A2DP v1.2, AVRCP v1.0, HSP v1.2, HFP v1.6
- Bluetooth RANGE: Up to 10m (33 feet)
- Bluetooth VERSION: Bluetooth v2.1 +EDR
- COLORS: Black or White/Brushed Aluminum
- DIMENSIONS: 9.9″ H x 7.5″ W x 2.7″ D
- DRIVE COMPONENTS: Full Range KG 150
- DRIVER DESIGN: Dynamic Moving Coil 40mm Speaker
- DRIVER DIAMETER: 40mm
- FREQUENCY RESPONSE: 16Hz-23kHz
- IMPEDANCE: 32 ohms
- INPUT CONNECTIONS: 3.5mm
- MIC/REMOTE: Integrated mic and earcup controls
- SENSITIVITY: 110dB
- STYLE: Wireless on-ear
- WEIGHT: 181 grams
