Klipsch’s Heritage Wireless Speaker Series Now Includes The Sevens and Nines
The brand new Klipsch The Nines and The Sevens offer more power, MM phono preamplifiers, and larger and more powerful woofers to complete the Heritage Wireless series.
Klipsch The Fives, The Sevens and The Nines Heritage Wireless Speakers
Klipsch’s Heritage Wireless Speakers lineup has now expanded to three models; the brand new The Sevens and The Nines join the award-winning The Fives which were introduced in 2020.
All three models share the same design, functionality, and use 1″ titanium tweeters on Tractrix horns. The distinction is the use of three different sized woofers and more power as you move further up the lineup.
  • The Fives: 4.5-inch woofer
  • The Sevens: 6.5-inch woofer
  • The Nines: 8-inch woofer
All Klipsch Heritage Wireless speakers feature Bluetooth wireless technology, digital optical, analog RCA, USB inputs and a subwoofer output.
Klipsch The Nines Heritage Wireless Speakers Walnut Lifestyle
Klipsch The Nines connected to a turntable.
Klipsch have included an internal MM phono stage for those who wish to connect their turntables, and you can connect your TV to the primary speaker through the HDMI-ARC input.
The Fives, Sevens and Nines are all powered speakers, which mean they include built-in amplifiers. That greatly simplifies setup and negates the need for a separate power amplifier and pre-amplifier to control them.
Klipsch boasts its Heritage line supports hi-res audio up 24-bit/192kHz; you will need to connect them to your source device using a wired connection for that to happen.
Klipsch The Sevens Heritage Wireless Speaker Walnut Top Controls
The controls atop each Klipsch Heritage Wireless Speaker are the same (The Sevens shown).
Most users are likely to stream music wirelessly via Bluetooth, because built-in access to music streaming services (Spotify Connect or TIDAL Connect) is one feature missing that can be found in competing models, such as the SVS Prime Wireless Pro Wireless Speakers.
Designed with luxury materials such as real wood veneer and tactile switches and knobs, Klipsch’s Heritage Wireless Series blend the acoustics and classic design legacy of Paul W. Klipsch with the latest technologies available today.
Klipsch Heritage Wireless powered speakers incorporate award-winning, proprietary Klipsch Reference acoustic horn-loaded technology and tuning to deliver loud and precise audio with enhanced bass and low distortion.
Built-in dynamic bass equalization matches the ear’s ability to hear lower frequencies, delivering powerful bass at any volume.
Klipsch The Sevens Heritage Wireless Speakers Walnut with grilles off
Klipsch The Nines and The Sevens feature 1” titanium tweeters on Tractrix horns. Larger in size and output, The Nines feature 240W total system power and an all-new 8” long-throw high excursion composite cone woofer.
Meanwhile, the mid-sized The Sevens offer 200W total system power with a 6.5” long-throw woofer for room filling sound and extended bass response.
Klipsch’s The Nines and The Sevens powered monitors are compatible with the Klipsch Connect App, giving users access to customize EQ and subwoofer volume settings, dynamic bass, night listening mode, over-the-air firmware upgrades, a digital quick-start guide, and much more.
Klipsch The Sevens Heritage Wireless Speakers Rear Walnut
All Heritage Wireless Speakers have same rear connections (The Sevens shown).
Comparison
THE FIVESTHE SEVENSTHE NINES
MSRP$969$1,299$1,499
SYSTEM DESCRIPTIONPowered Monitor (pair)Powered Monitor (pair) Powered Monitor (pair)
FREQUENCY RESPONSE50Hz – 25kHz39-25kHz +/- 3dB 34-25kHz +/- 3dB
DYNAMIC BASS EXTENSION46Hz @ 35% Volume28Hz @ 35% Volume 22Hz @ 35% Volume
MAX OUTPUT109 dB (1M Stereo Pair)112 dB (1M Stereo Pair)115 dB (1M Stereo Pair)
TOTAL SYSTEM POWER160W Total System Power (320W Peak) 60W LF, 20W HF200W Total System Power (400W Peak) 80W LF, 20W HF240W Total System Power (480W Peak) 100W LF, 20W HF
LOW FREQUENCY DRIVER4.5” (11.43cm) high-excursion fiber-composite cone woofer6.5” (16.51cm) high-excursion fiber-composite cone woofer 8” (20.32cm) high-excursion fiber-composite cone woofer
HEIGHT, WIDTH, DEPTH12” (304.8mm) x 6.5” (165.1mm) x 9.25” (234.95mm)16.38” (415.9mm) x 8.13” (206.4mm) x 10.88” (276.22mm) 19.13” (485.8mm) x 9.5” (241.3mm) x 13.38” (339.7mm)
WEIGHTPrimary: 11.8 lbs (5.35kg) – Secondary: 10.7 lbs (4.85kg)Primary: 22.3 lbs (10.12kg) – Secondary: 19.9 lbs (9.03kg) Primary: 28.4 lbs (12.88kg) – Secondary: 27.0 lbs (12.25kg)
HIGH FREQUENCY DRIVER1” (2.5cm) Titanium LTS vented tweeter with Tractrix® horn
ENCLOSURE MATERIALMDF with genuine wood veneer
ENCLOSURE TYPEBass-reflex via rear-firing port
INPUTS• HDMI-ARC with CEC
• Bluetooth® 5.0 wireless technology
• Phono/Line analog (with switch and ground screw terminal)
• 3.5mm analog mini jack
• USB digital
• Optical digital
OUTPUTSSingle RCA line level output for connection to subwoofer
VOLTAGE100V-240V 50/60Hz internal power supply with region specific power cords
INCLUDED ACCESSORIES• Region-Specific power cord (2.0m)
• Remote control (with 2 x AAA batteries)
• 4-conductor speaker cable (4m)
• 4-conductor speaker cable extension (2m)
• USB Type-B to USB Type-A cable (1.5m)
• HDMI Cable (1.5m)
FINISHWalnut / Black
Klipsch The Sevens Heritage Wireless Speakers Black Lifestyle
Klipsch The Sevens
Price & Availability
All Klipsch Heritage Wireless Speakers are available now in Walnut and Black veneer finishes.
2 Comments
2 Comments
  1. alan
    February 1, 2023 at 12:19 am
    hopefully they’ve fixed the biggest problem with the Fives which is that there’s no smart input switching of any kind. seriously, if you connect to bluetooth you still have to walk over and flip the input selector to bluetooth. if they’ve figured that out then these will be dramatically better speakers.
    • Chris Flynn
      February 2, 2023 at 1:06 pm
      You can change inputs with the app.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
With improved drivers and the addition of an active crossover option, the Klipschorn AK7 and La Scala AL6 are ready to take on all...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
The Atelier program gives Bang & Olufsen's customers the chance to style their own speakers. The Beosound 2 Gradient Collection gets things started.
For 2025, the Audioengine A2+ now includes Bluetooth 5.3, 24-bit audio, and USB-C connectivity - still at an affordable price.
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
The new Klipsch Forte IV loudspeakers feature updated cosmetics and the latest advancements in acoustic engineering, while maintaining the original charisma that made the...
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
