Klipsch’s GIG XL & GIG XXL Loudspeakers Will Rock Your Next Pool Party
Your neighbors might hate you if you run a stereo pair of Klipsch’s GIG Party Loudspeakers. Your next pool party almost demands that you do.
Klipsch GIG XL and XXL Party Speakers
Klipsch has decided to enter the party speaker market with two entries, the GIG XXL and GIG XL. These portable party speakers are lightweight and designed to deliver great sound both indoors and outdoors.
Klipsch sees the party speaker market as a great fit as many of their speakers have already been used in dance clubs, listening lounges, and at college events for over 70 years. By entering the portable party speaker market they broaden their reach even further.
How GIG Party Speakers Are Different
The Klispch party speakers consist of two models so far, the Gig XXL and Gig XL. What makes these party speakers different from other Klipsch models is that they don’t incorporate Klipsch’s Horn Technology and feature a light show that can be synchronized to your music and is customizable based on user preference.
There are also inputs for microphones to inspire karaoke parties.
Tip: A wired microphone is included with each party speaker.
Klipsch GIG XXL Party Speaker for bands
Klipsch GIG XXL
Shared Features
Here are some of the shared features of the GIG XL and XXL.
True Wireless Bluetooth Stereo: Not only can you stream content to GIG speakers from your smartphone or other compatible Bluetooth source, but you can also use Bluetooth to pair two Klipsch GIG speakers together for a stereo listening experience.
Connection Flexibility: In addition to Bluetooth, the GIG party speakers also provide connection flexibility with 3.5mm, USB, and Karaoke mic inputs.
Multi-Colored Light Show: The GIG party speakers include multiple lighting modes to add more flavor to music listening and the party atmosphere.
Onboard Controls: Onboard controls are provided for input selection, volume control, audio settings, and lighting effects. The XXL also includes guitar volume and echo control.
Playtime: At full volume, the party speakers will last up to eight hours thanks to their class-leading rechargeable lithium batteries.
Tip: You can also plug the GIG party speakers into AC Power.
GIG XXL
Klipsch GIG XXL is the larger of the two speakers and incorporates two 2-inch tweeters and two 6.5-inch woofers with bass boost mode for big, powerful party sound.
For musicians, the GIG XXL features a 1/4-inch instrument cable input compatible with most guitars, keyboards, drum machines, and more.
GIG XL
Klipsch GIG XL Party Speaker
 Although the Klipsch GIG XL is smaller, it is still designed for a great listening experience as well as user flexibility.
The GIG XL has a more modest sound system than the XXL, with one 2-inch tweeter and one 6.5-inch woofer with a bass boost mode
Also, unlike the GIG XXL, the XL has an IPX4 rating which allows it to safely withstand water splashes and rain.
Klipsch GIG XL Party Speaker is IPX4 rated for use near a pool
Comparison
GIG XLGIG XXL
MSRP$249 $349
BluetoothYes (includes Bluetooth Stereo)Yes (includes Bluetooth Stereo)
Inputs3.5mm Analog, USB, Karaoke, Mic3.5mm Analog, USB, Karaoke Mic, Guitar
Light ShowYes – RingsYes – Rings and Strobes
Onboard ControlsYesYes
TweeterOne 2-inchesTwo  2-inches
WooferOne 6.5-inchesTwo 6.5-inches
Max Acoustic Audio Output (SPL)105db@.5 meters110.7db@.5 meters
Frequency Response (+/- 3dB)60Hz to 20kHz50Hz to 20kHz
Power Input 110/220  volts110/220  volts
Battery TypeRechargeable Lithium
(7.4 volts/2200mAh)
(7.4 volts/4400mAh)
Battery Life8 hours8 hours
Waterproof RatingIPX4Not Rated
Included AccessoriesAC Power Cord, Karaoke MicAC Power Cord, Karaoke Mic
FinishABS and perforated metalABS and perforated metal
Dimensions (HWD-mm)355 x 255 x 230551 x 275 x 290
Dimensions (HWD-inches)13.98 x 10.04 x 9.06 21.69 x 10.83 x 11.42
Weight (kg)8.2
Weight (lbs)18
Top View of Control on Klipsch GIG XL and XXL Party Speakers
Availability and Price
The Klipsch GIG Party Speaker line is available now directly from Klipsch and Authorized Dealers.
Tip: More on Klipsch Speakers
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
DAPs
With support for 32-bit PCM, DSD, Roon, LDAC, aptX HD, and a brand new docking cradle, the Astell&Kern PS10 DAP might replace your streamer.
With improved drivers and the addition of an active crossover option, the Klipschorn AK7 and La Scala AL6 are ready to take on all...
Incorporating the Apple H2 chip, Bluetooth, spatial audio, wireless charging and more, the Beats Powerbeats Pro 2 wireless earbuds offer a lot for just...
Digital Music Systems
The Audioengine B1 has been updated with Bluetooth 5.3, aptX Adaptive, and 32-bit Audio, but still has the same $189 price tag
Priced at $234.99, the Cleer ARC 3 Gaming Edition comes with a USB-C dongle for low latency wireless gaming.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
The new Klipsch Forte IV loudspeakers feature updated cosmetics and the latest advancements in acoustic engineering, while maintaining the original charisma that made the...
