Loudspeakers
Klipsch Gallery G-17 Air Wireless AirPlay Speaker
Klipsch expanded its Gallery Series Speakers with the new Gallery G-17 Air AirPlay Wireless Speaker. The G-17 Air allows wireless access and playback of your iTunes libraries from your Apple smart device, such as an iPad, iPhone or iPod touch capable of running iOS 4.2. Android-based smartphones and tablets can also stream to the speaker if used with Android's music player app. Simply plug the G-17 into your wall, and connect wirelessly over an existing Wi-Fi network.
At 17 inches long, the G-17 Air effortlessly pumps out robust sound with deep bass and clear dynamic range. Complete with the proprietary Tractrix Horn, Klipsch claims you'll hear all the power, detail and emotion you expect from a live performance.
The elegantly shaped, high density resin cabinet is finished with a unique, twelve-step process that produces a piano black, high gloss luster that emulates a fine musical instrument, and mounts vertically or horizontally on a wall.
Features
  • AirPlay enabled speaker connects wirelessly over an existing Wi-Fi network
  • Allows control of your iTunes library from your Apple smart device
  • Employs horn-loaded technology in an extremely thin speaker
  • Sleek, minimalist cabinet in high-gloss piano black finish
  • Wall mount or use the included dark glass base
Specifications
  • AMPLIFIER POWER: 2 x 20W RMS (woofers) 2 x 10W RMS (tweeters), Bi-Amplified for audiophile resolution
  • BUILT FROM: 2011
  • CROSSOVER FREQUENCY: 3kHz
  • ENCLOSURE TYPE: Bass-reflex
  • FINISH: High Gloss Black
  • FREQUENCY RESPONSE: 57Hz – 23kHz ±3dB / useable bass to 47 Hz (f10)
  • HIGH FREQUENCY DRIVER: 0.75″ (1.9 cm) Aluminum diaphragm compression driver mated to 90° x 90° square Tractrix Horn
  • INPUTS: Apple AirPlay, 3.5mm Analog In, USB for Digital Input from iPod
  • LOW FREQUENCY DRIVER: Two 2.5″ (6.35 cm) long-throw IMG woofers
  • MAX ACOUSTIC OUTPUT: 102 dB (near field)
  • MOUNTING: Dual keyhole for wall mounting
  • DIMENSIONS:
    Without Base: 6″ H x 16 7/8″ W x 3.5″ D
    With Base: 7″ H x 16.87″ W x 4″ D
  • WEIGHT: 7.5 lbs
Price and Availability
The Klipsch Gallery G-17 Air AirPlay Speaker will be available for $529.99 fall 2011.
See more about: Speakers, AirPlay, Wireless Speakers, Klipsch
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
With improved drivers and the addition of an active crossover option, the Klipschorn AK7 and La Scala AL6 are ready to take on all...
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
The new Klipsch Forte IV loudspeakers feature updated cosmetics and the latest advancements in acoustic engineering, while maintaining the original charisma that made the...
Klipsch, Onkyo and Integra have been swept up in Gentex's acquisition of VOXX International. Can they all survive in 2025?
Daily Deals
Our favorite soundbars on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
In this episode the eCoustics teams reveals its Best in Show product awards from CEDIA Expo 2024 across 17 different categories.
At $8,498/pair, only a limited number Klipsch + Ojas kO-R1 two-way multicelled loudspeakers will be handcrafted in Hope, Arkansas.
