Klipsch Introduces Flexus Soundbar Systems in Collaboration with Onkyo
Klipsch has two new soundbars priced under $500 that work with optional wireless surround speakers and subwoofer.
Klipsch Flexus Soundbar Lifestyle
Legendary speaker maker Klipsch, is now releasing its new Flexus Soundbar Systems Powered by Onkyo that we first learned about at CES 2024. Although Klipsch has been making soundbars for over a decade, their new Flexus line represents the first time they are collaborating with well-known AVR maker Onkyo on the amplifier and audio processing side of the equation. Klipsch claims that the Flexus soundbar series incorporates advances in audio performance, connectivity, modularity, and setup – all at a reasonable price point.
Klipsch FLEXUS Sound System Logo
Flexus Overview
The system includes the Flexus Core 100 and Core 200 sound bar models, the Flexus Surr 100 wireless surround speakers, and the Flexus Sub 100 wireless subwoofer
The Flexus Sound System features an electronics package to ensure reliability. It is claimed that each Flexus product undergoes over 1,000 points of rigorous testing developed and executed by Klipsch’s and Onkyo’s combined research and development teams. No details, however, have been provided so far as to what some, or all these testing points are.
Flexus Core 100 Sound Bar
Klipsch Flexus Core 100 Soundbar
The Core 100 is the entry model in the Flexus series. It is a 2.1-channel soundbar incorporating Dolby Atmos decoding with flexible connectivity, including HDMI eARC, optical, USB-C, and Bluetooth.
The new Klipsch Connect Plus app for iOS and Android® devices provides one-tap access to input selection, EQ presets, firmware updates, and more.
Despite its small 28-inch width, this soundbar is designed to deliver more than you think, thanks to high-efficiency 2.25-inch aluminum drivers and dual 4-inch built-in subwoofers.
Flexus Core 200 Sound Bar
Klipsch Flexus Core 200 Sound Bar
Building on the Core 100 feature platform, the Core 200 is a 3.1.2-channel sound bar. At 44 inches wide, the Core 200 engages listeners in an immersive Dolby Atmos experience with two 2.25-inch elevation drivers, four front-firing 2.25-inch aluminum drivers tuned by Klipsch, and dual 4-inch built-in subwoofers.
For enhanced vocal intelligibility and clear dialog at any volume, the Core 200 features Klipsch horn loading technology for the dedicated center-channel tweeter.
Expansion Options
The Flexus Core 100 and Core 200 soundbars improve TV sound for music and movies, but they are also designed for modular expansion with optional surround speakers and subwoofers.
Flexus Surr 100 Wireless Surround Speakers
Klipsch Flexus Surr 100
The Flexus Surr 100 wireless surround speakers incorporate 3-inch full-range drivers. In addition, flexible placement and wall-mounting options are provided to create the optimum multichannel surround-sound experience. Simplifying setup and ease of use, each Flexus does not need any wires to connect to the sound bar as audio is transmitted wirelessly. However, these speakers do need to be plugged into a wall outlet to supply power to their built-in amplifiers.
Flexus Sub 100 Wireless Subwoofer
Klipsch Flexus Sub 100 Subwoofer
The Flexus Sub 100 wireless subwoofer delivers powerful bass with plenty of depth thanks to its high-excursion paper-cone woofer, without sacrificing the low latency and musicality typical of larger subwoofers. Its compact, sealed design allows the Flexus Sub 100 to fit in tight spaces. The Flexus Core models accommodate the pairing of two subwoofers, for larger rooms and epic bass.
Easy Setup
Klipsch’s Transport technology makes setting up and connecting the Flexus family of products across multiple channels easy with the pre-paired USB transmitter, included with Flexus surrounds and Flexus subwoofers, allowing the Flexus Core models to quickly connect and expand the system by eliminating complex configuration steps.
Klipsch Flexus Transport Wireless Transmitter
Klipsch Style
Built to last and styled with premium materials influenced by Klipsch’s long heritage of classic design, the Flexus components easily blend with modern electronics and interior décors. All models feature rounded vertical edges for a softer, subtler appearance. The sound bars offer wood grain-textured top panels accented by metal grilles covering the upfiring drivers and cloth-wrapped front and sides.
Klipsch Flexus Remote Control
Comparison
Core 100Core 200Surr 100Sub 100
MSRP$349$499$249$299
TypeSoundbarSoundbarSurround SpeakersSubwoofer
Speaker System2.1 channel Soundbar with Virtual Dolby Atmos3.1.2 channels with Dolby Atmos2.0 Wireless Surround  Speakers (Pair)Subwoofer with Built-in Class D Amplifier
Enclosure TypeSealedSealedSealed Sealed
Max Acoustic Output (SPL)96.4 dB99.8 dB103.5 dB103.7 dB
Front Firing Drivers2 x 2.5-inch Aluminum Cone4 x 2.25-inch Aluminum Cone
1 x .75-inch Horn Loaded Tweeter
1 x 3-inch Paper Cone Full Range10-inch Front Firing Long Throw Paper Cone
Upfiring Drivers2 x 4-inch Paper Cone Woofers2 x 4-inch Pape Cone Woofers
2 x 2.5-inch full-range drivers
Not StatedNone
System Power100 Watts RMS105 Watts RMS50 Watts RMS80 Watts RMS
160 Watts Peak
Frequency Response45Hz to 20kHz43Hz to 20kHz235Hz – 20kHz26 – 250 Hz (+/- 3dB)
InputsHDMI (eARC), Bluetooth, USB–C, Digital OpticalHDMI (eARC), Bluetooth, USB–C, Digital OpticalWireless via Flexus TransportWireless via Flexus Transport
RCA LFE/Line-in
OutputsSubwooferSubwooferN/A
Dimensions (HxWxD)3 x 28 x 5 inches
(7.6 x 71 x 12.7 cm)
3.1 x 44 x 4.9 inches
(7.8 x 111.8 x 12.6 cm)
6.75 x 4.13 x 4.31 inches
(17.1 x 10.5 x 10.9 cm)
13.38 x 13.19 x 13.75 inches
(34 x 33.5 x 34.9 cm)
FinishEbony VinylEbony VinylEbony VinylEbony Vinyl
Voltage /Power Supply100/240 – 50/60Hz Internal100/240 – 50/60Hz Internal100/240 – 50/60Hz Internal100/240 – 50/60Hz Internal
Weight 10 lbs (4.54kg)18.7 lbs (8.5kg)2.5 lbs (1.13kg) each20.7 lbs (9.4kg)
Included Accessories 1 x Backlit Remote Control with batteries
1x Power Cord
1 x HDMI Cable
2 x L-shaped mounting brackets
1 Mounting Hardware
1 x User Manual
1 x BLE Backlit Remote Control with batteries
1x Power Cord
1 x HDMI Cable
1 Mounting Hardware
1 x User Manual
2 x Right-Angle IEC Power Cord
1 x Flexus Transport Wireless dongle
1 x User Manual
1 x Right-Angle IEC Power Cord
1 x User Manual
Mounting Option¼-inch 20 Thread¼-inch 20 Thread¼-inch 20 ThreadFloor standing
Klipsch Flexus Soundbar System Core 200 with Sub 100 and Surr 1000
Pricing & Availability
The Flexus Sound System is now available from authorized US retail partners at the following prices.
  • Flexus Core 100: $349
  • Flexus Core 200: $499
  • Flexus Surr 100: $249
  • Flexus Sub 100: $299
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Explore Craft Recordings' Record Store Day 2025 preview featuring exclusive releases from Carla Thomas, Thelonious Monk with Gerry Mulligan, and the Jazz Dispensary Night...
